Slipping clutch - Road Glide Forums
post #1 of 20 (permalink) Old 06-05-2013, 03:30 PM Thread Starter
Slipping clutch
2011 RGU with 20,000 miles---- nearly half of those long highway miles with the rest mixed.
I believe my clutch is slipping. I believe I feel it mostly in 3rd, 4th, and 5th gears. Seems like it's early to have this issue.
Have any of you had an experience like this? Any info or insight you can provide will be appreciated.
Maybe I just got lucky.
Thanks for the help with this
Craig
craigp95 is offline
post #2 of 20 (permalink) Old 06-05-2013, 03:40 PM
RGUrider's Avatar
had same issue, same year 2011. Mileage closer to 10K. After I adjusted clutch, no more slipping.
RGUrider is offline
post #3 of 20 (permalink) Old 06-05-2013, 04:32 PM
JacktheBagger's Avatar
Mine made it to almost 25000 before I had to adjust , but wasnt slipping .
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 20 (permalink) Old 06-05-2013, 04:33 PM
I had a prob with my clutch lunging from day one, had dealer look at it and said was caused from yaffe bars I installed, told them was from day one that I never had a bike with a transmission and didn't know the difference until cousin rode it. long story short they called yaffe and confirmed wasn't the bars pulling my cable and warranty replaced my cable and clutch. dealer said they can do this once without a lot of grief from warranty people so give it a try and good luck. sorry for long write up, hope it helps
2012 Crome Yellow,10" Bagger Nation monkey bars
V and H Pro pipe, Fuelpak, Throttlepak
S/E Heavy Breather, CVO windscreen
jstucker1976 is offline
post #5 of 20 (permalink) Old 06-05-2013, 04:39 PM
103_FBob's Avatar
2011 RGU. 23,000 miles. Clutch replaced.
Went with the Screamin Eagle which was recommended with my 107" setup. I like it much better. Stiff. But I like it a lot more than the stock even before slippage started.
2011 FLTRU : 107ci : Stage II Heads : Jackpot 2-1-2 Headers : Jackpot Carbon-Billet Slip-on's : SE Ventilator : TTS MasterTune
2008 FXDF : 103ci : Stage II Heads : SE Heavy Breather : Rinehart 2-2 Staggered Exhaust : TTS MasterTune
103_FBob is offline
post #6 of 20 (permalink) Old 06-05-2013, 04:48 PM
Stock motor? What are you running in the primary? The only bike I ever had clutch issues with is my Dyna with a 95 kit and heads. It would slip in 4th and 5th. Used Drag ASpecialties primary oil and added a s/e clutch spring, problem gone. My RG has the Scorpion billet clutch set up in it.
HogPro is offline
post #7 of 20 (permalink) Old 06-07-2013, 12:43 PM Thread Starter
Thanks
Thanks for the info.
204 cam, breather & D&D Fatcat, TTS mastertune----stock otherwise. Using Amsoil 20w50 in the primary same as I did in the Softail. I think I'll try adjusting this weekend and see what happens.
craigp95 is offline
post #8 of 20 (permalink) Old 06-22-2013, 02:49 PM
I had a similar issue. My clutch was slipping. I took it in for a 25k service. They found that the clutch pak was coming apart. Thankfully I have the extended warranty and it is all covered. They are putting in the SE clutch pak and the SE spring without me asking. I would say this might be a known issue or at least becoming a trend for them.
Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity. George S. Patton
jlucke89 is offline
post #9 of 20 (permalink) Old 06-22-2013, 09:35 PM
LegacyNoShow's Avatar
Craig
This is what worked for me. Same issues, turned out to be the "trap door bearing" Took it to the dealer and when I asked him about it he already knew what I was talking about. Apparently it's and issue with some 2011, and 2012's..Link to the thread below. Some said it's hocus pocus, but it worked for me and is still working fine. No issues and that was 6k ago...Good Luck, BTW if it's under warranty HD will foot the bill...
https://www.roadglide.org/showthread.php?t=32348
2012 FLHTRU 103"/Freedom Performance duals/Cobra power port headers/Fi2000 Power Pro tuner/18" apes/Stage II Big Sucker/13" dark smoked Madstad/Gabriel air ride
LegacyNoShow is offline
post #10 of 20 (permalink) Old 06-23-2013, 01:09 PM
rageglide's Avatar
You ever round up the parts list to figure out what exactly they replaced? Was it just the trapdoor bearings or was it the throwout bearing. Just curious.
2012 fltrx
rageglide is offline
Clutch slipping 1st Sgt Troubleshooting for Road Glides 43 07-24-2014 11:10 PM
Hydraulic Clutch Slipping phillyrube Troubleshooting for Road Glides 3 05-05-2013 04:53 PM
2011 RGU Clutch Slipping brhodea *General Road Glide Discussions/Pictures 12 03-29-2013 02:28 PM
Clutch Slipping? PhrogFlyer Troubleshooting for Road Glides 17 03-11-2013 06:12 PM
stock 103 possible smoked clutch/slipping trans OuchMMC Engine Related 23 10-13-2012 10:29 PM
