Primary oil in the starter motor - Road Glide Forums
post #1 of 6 (permalink) Old 06-06-2013, 08:18 PM Thread Starter
sj01fltri's Avatar
has any one had a problem with primary oil filling the starter motorand having the oil run out of the back of the starter,its not the seal on the out side of the starter housing which seals to the inner primary,it appears to going down the starter jacksaft into the starter,its on an 09 RG that belongs to a riding buddy,my first guess is that the starter housing may be cracked
sj01fltri is offline
post #2 of 6 (permalink) Old 06-06-2013, 08:21 PM
Torquey's Avatar
Wow...weird one. Wish I could help. Anybody?
Torquey is offline
post #3 of 6 (permalink) Old 06-08-2013, 04:14 PM Thread Starter
sj01fltri's Avatar
As i suspected the snout on the starter was cracked so as it would heat up the crack would open up.dont think the housing itself is available,so looks like he may have to buy a new one ,ouch.
post #4 of 6 (permalink) Old 06-09-2013, 08:45 AM
That's exactly what happened to me. Dealer said some of the 09 starters were bad. But I ended up buying a new one. While he's at it have him change out his compensator to the SE. Compensator, he'll have to soon anyway.
2009 Hot Red Sunglo, 107 build, S&S 551 cams, heads polished and ported, Vance & Hines Dresser Duals, Vance and Hines 4" rounds, REVOLUTION PERFORMANCE ems, Bad Seed bars, J&M amp and rokkers speakers, Sony DSX-S310, progressive 940's
RoadGlide0611 is offline
post #5 of 6 (permalink) Old 06-09-2013, 10:57 AM
You can change out the starter without opening up the primary on the 09s and up. Although a bad comp will eventually wipe out the new starter so i would recommend a new comp anyways
post #6 of 6 (permalink) Old 06-10-2013, 03:48 PM
Has anyone here tried an aftermarket starter? I didn't see this post before I started a new thread.
2007 Heritage vivid black 48,000 miles
2008 Ultra Classic candy red sunglow 45,000 miles
2011 RGU vivid black soon with new graphics 20,000 miles and gaining
DEMONDGE is offline
How to rebiuld you starter motor for $11.00 lundboy1 Do-IT-Yourself 16 06-10-2019 09:07 AM
2008 FLTR Starter-Motor, Compensator, Questions Bull_Duck Troubleshooting for Road Glides 15 11-02-2015 06:58 AM
Motor oil residue in air cleaner BLammers Engine Related 5 02-11-2015 07:11 AM
Right front motor mount has oil on it...where is the leak? HogPro *General Road Glide Discussions/Pictures 26 04-29-2014 02:49 PM
Just did a primary oil change JTultra Road Glide Specific Discussions 8 07-21-2011 08:59 PM
