Cometic head gaskets - Road Glide Forums
post #1 of 10 (permalink) Old 06-06-2013, 09:35 PM Thread Starter
Hey guys, just wondering which thickness I should get to be the same as stock on a '12 103? Or maybe you have an opinion on another brand that you feel is better? Also where to get them?
Thanks!
pat84 is offline
post #2 of 10 (permalink) Old 06-06-2013, 10:13 PM
Why go stock put a .030 in there raise the compression towards 10.1. If you have got some cams they will like it. Cometic gaskets are very good.
JTultra is offline
post #3 of 10 (permalink) Old 06-06-2013, 10:34 PM Thread Starter
It's got a turbo on it. I'm considering going thicker actually. Chalk this one up to learning a lesson.
pat84 is offline
post #4 of 10 (permalink) Old 06-07-2013, 07:26 AM
prodrag1320
Guest
Posts: n/a
a bigger part of the benefits of the .030 gaskets is not just raising the compression,but is to close up the squish.a tight squish will help with fuel burn and starve off detionation.with a turbo,i would still go with the .030 cometic and dish the piston to releave compression (i HOPE your running forged pistons)
post #5 of 10 (permalink) Old 06-07-2013, 11:55 AM Thread Starter
I am not running forged pistons, and I do not have the benefit of a machine shop at my disposal or anyone close that knows what their doing.
pat84 is offline
post #6 of 10 (permalink) Old 06-08-2013, 07:50 AM
prodrag1320
Guest
Posts: n/a
running a turbo with cast pistons is a recipeit for disaster
post #7 of 10 (permalink) Old 06-08-2013, 10:30 AM Thread Starter
Please explain to me why.
pat84 is offline
post #8 of 10 (permalink) Old 06-08-2013, 10:35 AM
pat123's Avatar
When you turbocharge a engine you increase the cylinder pressure the stock pistons can't take those pressures for very long. Motor go BOOM!
pat123 is offline
post #9 of 10 (permalink) Old 06-08-2013, 11:57 AM
Shark of the Month October 13
Location: Was northern Maine, now gulf coast of Florida
Yup, forged pistons with a turbo are pretty much standard fare, whether it's an HD mill or a motor for a 4-wheeled vehicle. Two new pistons are a lot cheaper than what it will cost you if the standard pistons go boom.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming “Wow! What a Ride!” - HST
Uncle Fuzzy is online now
post #10 of 10 (permalink) Old 06-08-2013, 12:02 PM
If your turbo is a Trask, contact them and see what they recommend.
Contact Cometic and see what they recommend.
Both of these companies have a lot of their product out there.
HeatWave is offline
.030 Head Gaskets in the HO 103's 303RG Engine Related 15 03-20-2016 11:49 AM
Cometic Gasket part number? Damage-Case Engine Related 2 01-08-2016 09:15 PM
Which head gaskets in 92500005 iv kit Sloverado Engine Related 1 02-17-2015 04:51 PM
Head Pipe Gaskets Bud Intake and Exhaust 6 02-24-2011 09:56 PM
