Motor still knocking after cases replaced. - Road Glide Forums
 10Likes
post #1 of 32 (permalink) Old 05-30-2018, 09:24 AM Thread Starter
Motor was tore down for top end knock and had cases replaced. Lifter bores were scored. I guess they thought that was causing the knock. So motor was put back together with new cam bearings and lifters. 300 miles into the new motor we get the same knock. Same heads pushrods cams and jugs and cylinders were reinstalled. Bike carries recommend oil pressure according to the digital display. After it warms up it knocks quieter but it is still there. Any rpm over 3500 it sounds like it is eating itself. Can you guys go to the link and listen to it and tell me what you think it is. Piston slap ? Bad heads valves ? Surly it’s not the lifters. They have been replaced 3 times and every time the same knock is there. I am at a loss here and I would think the dealer would be also. I think they should rebuild the entire top end and see if that fixes it. Who knows. Thanks for everyone’s opinion. Anything might help. https://youtu.be/R7Pkw26cdB0
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #2 of 32 (permalink) Old 05-30-2018, 09:27 AM Thread Starter
Oh and the knock is only in the front cylinder. Has always been in front cylinder from the begging of this problem.
post #3 of 32 (permalink) Old 05-30-2018, 10:09 AM
Yea it realy nocks bad ,send it to Fuelmoto or T man and ask on their opinion, good luck
Skickat från min iPhone med Tapatalk
ultra98 is offline
post #4 of 32 (permalink) Old 05-30-2018, 10:15 AM Thread Starter
I am about ready to call for your Moto and set up appointment to have them rebuild it. Obviously the dealer has no idea what’s wrong with it.
post #5 of 32 (permalink) Old 05-30-2018, 10:18 AM
Ok keep us posted whats happens
ultra98 is offline
post #6 of 32 (permalink) Old 05-30-2018, 12:27 PM
If the bike is still under warranty you should stick with the dealer. Also if the dealer did the work they should back the work. If you go somewhere else it may cost you money unless you have a extended warranty. Get a mechanics stethoscope and listen to the engine and see if you can narrow down the problem.
Little Wing likes this.
post #7 of 32 (permalink) Old 05-30-2018, 07:12 PM
If that’s under warranty it needs an engine. Get a lawyer if under warranty.
dreeves is offline
post #8 of 32 (permalink) Old 05-30-2018, 07:32 PM Thread Starter
Why do you think it needs a new engine ? You please explain.
post #9 of 32 (permalink) Old 05-30-2018, 10:50 PM
BigBlockBobby's Avatar
Hard to say by a video. Could be a rocker, lifter, pushrod adj, valve seat, etc. Can you tell what area the noise is coming from?
BigBlockBobby is offline
post #10 of 32 (permalink) Old 05-30-2018, 11:35 PM Thread Starter
Coming from the front head or cylinder.
Engine Knocking bike51 Engine Related 24 07-01-2016 09:55 AM
Engine Cold, bad knocking noise at idle... Scootin Engine Related 18 06-02-2016 08:14 AM
103 idle knocking HDMARK Troubleshooting for Road Glides 13 06-29-2012 02:19 PM
Ticking and knocking ransom1567 Troubleshooting for Road Glides 0 05-28-2012 10:25 AM
knocking or metallic sound big papa *General Road Glide Discussions/Pictures 1 10-18-2011 06:54 AM
