Time foer another game of name that noise! - Road Glide Forums
 5Likes
  • 1 Post By shelton
  • 1 Post By ironmark
  • 3 Post By Morningwood
post #1 of 7 (permalink) Old 06-02-2018, 09:02 PM Thread Starter
Rabbit_'s Avatar
Hi all,
I've got a rattle that I can't figure out, my Softail doesn't make this noise and it only comes on when I throttle up. Everything sounds fine at idle or just cruising along but comes on as soon as I give it any throttle.
I don't know if this is the infamous rocker tick or what, but I've never experienced this on any other Harley. I'm hoping someone is able to help identify it before I go to the dealer. She's a 16 RGS with a 113in stage 4.
Any help will be appreciated.
https://youtu.be/JGNgCjUNTG8
Rabbit_ is offline
post #2 of 7 (permalink) Old 06-07-2018, 04:37 PM
Kind of sounded like a possible exhaust leak but hard telling from that clip...Iíll agree that it doesnít sound normal
Eddie Haskell is offline
post #3 of 7 (permalink) Old 06-07-2018, 04:48 PM
MightyWhitey's Avatar
Could be a lot of things. I have experienced similar sounds that only become audible at certain rpms and theyíve been things loose on the bike. One was a heat shield that even though felt tight it didnít like a vibration caused by a certain rpm and it would rattle fir just a few hundred rpm.
Tough to say from a video clip. If youíre mechanically inclined Iíd start checking things like heat shields for evidence of rubbing before letting anyone start tearing into the motor. Good luck to you. Let us know what you find.
MightyWhitey is offline
post #4 of 7 (permalink) Old 06-07-2018, 06:36 PM Thread Starter
Rabbit_'s Avatar
Thanks guys,
I've been looking for something loose that would be causing it but haven't found it yet. I'm putting her up on the jack tomorrow to do a better search front to back. If I find it I'll post it.
Rabbit_ is offline
post #5 of 7 (permalink) Old 06-08-2018, 07:38 AM
check your exhaust heat shield at the RH, floor board when you accelerate your engine will shift on the mounts and could be making contact there. also check to make sure the air breather cover is not making contact with the fuel tank if it has been modified.
Rabbit_ likes this.
shelton is offline
post #6 of 7 (permalink) Old 06-08-2018, 11:38 AM
Good possibility that it's just throttle body noise. Throttle body will make noise that kind of sounds like a bad lifter. Doing engine upgrades and air filter upgrades will allow more noise to come out of the throttle body and it is nothing to worry about.
Rabbit_ likes this.
post #7 of 7 (permalink) Old 06-08-2018, 12:17 PM
Morningwood's Avatar
Hard to tell but the same sound I had when accelerating, I had assumed it was an exhaust leak so to rectify it I bought a whole new exhaust, the sound is now gone. I figured if was going to have to pull the header and change the gasket might as well replace the whole thing, it was cheaper this way I didn't have to buy new gaskets they were included with the new exhaust.
Morningwood is offline
Just another name... JG762 New Members Welcome Area 13 07-02-2016 06:58 AM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
NFC Championship Game SharkNose General Off-Topic Discussions 17 01-18-2011 12:44 PM
