Geared cams on my '10 - Road Glide Forums
post #1 of 16 (permalink) Old 06-08-2013, 07:58 PM Thread Starter
Hey still new to the Harley game here. But are the cams on my '10 96" geared? If so, when did they do away from the chain gentoo we setup? Thanks.
2010 FLTRX- Black Denim, Rev Tech Dominator 18's w/matching rotors, RSD grips, RSD air cleaner, Vance and Hines pro pipe, Power commander V, chopped wind screen.
Torkmnstr is offline
post #2 of 16 (permalink) Old 06-08-2013, 08:12 PM
Stock cams have chain drive & the dreaded cam chain tensioners.
12 RGU Ember Red Sunglow
Heated Hammock seat, CVO bars
Decat, heated grips
billy t is offline
post #3 of 16 (permalink) Old 06-09-2013, 01:47 AM Thread Starter
Ah that is what I was wondering. So I have heard that the tensioner let go between 15 and 30k. Is that about right?
post #4 of 16 (permalink) Old 06-09-2013, 02:46 AM
1BigGuy's Avatar
The most recent change to the HD chain drive cams was an upgrade to the chain tensioner in the 2007 models. I haven't heard of any major issue since then, but then I really haven't been looking for reports either.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #5 of 16 (permalink) Old 06-09-2013, 06:47 AM
Since they went hydraulic in 07, the cam tensioner wear has been nil, my last bike (07 EG) showed almost no wear at 30k. On my present bike I went with geared cams because I had crank work done.
post #6 of 16 (permalink) Old 06-09-2013, 06:50 AM
BlackDangerous's Avatar
Geared cams are so much more precise!! JMO
BlackDangerous is offline
post #7 of 16 (permalink) Old 06-09-2013, 08:21 AM
prodrag1320
Guest
Posts: n/a
be carefull with gear drives in 96"ers as the lower ends have a tendecy to shift more(with the hyd. tesioners,their not a "must" like the 99-06)
post #8 of 16 (permalink) Old 06-09-2013, 11:34 AM
With the new hydraulic cam chain tensioners there is no need to worry about the tensioner wear unless the bike is a 2006 or earlier model that has the 88" engine. Stick with the chain drive cams because they are more forgiving when it comes to crank run out.
post #9 of 16 (permalink) Old 06-09-2013, 11:48 AM
Lunchbox's Avatar
The factory produced geared cam was 2000 for the softails, and 1999 for the Dynas and some touring models (this is when HD shifted from the Evo to the Twinkie).
Now if you must have gear driven cams I'd suggest crank work and a Timken bearing kit installed because with .005" runout service limit can be scary if you hot-rod your motor.
2013 FLTRU
Lunchbox is offline
post #10 of 16 (permalink) Old 06-09-2013, 06:40 PM
rageglide's Avatar
Easier to say Last Factory equipped gear driven big twins were Evo's... long live the Evo! I'll have you know the HD Factory guys who were showing off the twinkie motor at Sturgis in '99 did NOT appreciate me using that nickname... ;-) They were still pushing Donnie Petersons "Fathead" nickname...
.005" service limit? Maybe back in the early twinkie days. Current Acceptable Maximum is .000-.012" and Service limit is .014" Crazy! My '12 has .007" when I checked it few weeks ago. S&S states max .003" runout limit as I recall, else stay with chains.
2012 fltrx
rageglide is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Primary drive Geared like victory? ken2012 *General Road Glide Discussions/Pictures 17 08-30-2014 12:51 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
02 RG- Thunderheaders 2:1, SE253 cams, SE 95ci w/ 10.25:1, SE A/C, PC-III, Blueprinte adrenilinecrash Dyno Results 5 04-14-2013 07:21 AM
