2018 117” engine upgrades? - Road Glide Forums
post #1 of 3 (permalink) Old 06-08-2018, 09:23 AM Thread Starter
Does any one know which cam works good with this engine, or any other upgrades that work well?
Sanman67 is offline
post #2 of 3 (permalink) Old 06-17-2018, 10:31 AM
I did a Fuel Moto 124 kit and made 144hp & 138tq. Woods wm8-408 cam.
dplenzig is offline
post #3 of 3 (permalink) Old 06-22-2018, 11:53 PM
Depends how far you want to go. You can do the ported heads and then go with a radical lift cam. Cause when you do the heads, you can upgrade the valve springs for higher lift cams. Upgrade your throttle body to the 64mm. Or if you just want a "bolt-in" cam (basically plug-n-play) get the Zippers 468 cam. I recently did the TB, cam, cam plate and pump since I was in cam chest already do the cam job. That 468 cam wakes up the 117. Pulls hard from mid-range up. Pulls really good in 6th even. Now that I've done the cam, I'm kicking myself for not doing the ported heads now. Geezus, this hobby is going to send me to the poor house....well atleast I get to ride there...hah!
2018 CVO RG Stage III
2017 Road King Special Stage IV
*Tilting MotorWorks Converted*
Wheelz is offline
Hard to find photos of 10” Factory47 bars Fallenares *General Road Glide Discussions/Pictures 12 05-07-2018 02:49 PM
2018 CVO M8 117, Wood 22X cam, Jackpot 2/1/2, S&S mufflers fuelmoto Fuel Moto 6 01-12-2018 10:02 AM
2018 CVO M8 117, Wood 22X cam, Jackpot 2/1/2, S&S mufflers fuelmoto Dyno Results 4 12-15-2017 03:23 PM
2018 CVO 117" dyno testing Fuel Moto fuelmoto Dyno Results 4 11-14-2017 02:45 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
