Which To Use - Road Glide Forums
View Poll Results: Which Cam Plate and Oil Pump To Use
SE 1 14.29%
Fueling 6 85.71%
Other 0 0%
Voters: 7. You may not vote on this poll
post #1 of 8 (permalink) Old 06-09-2013, 09:24 AM Thread Starter
BlackDangerous's Avatar
Which To Use
I am looking to do another engine project and I am putting together a list of parts that I want to use. some of them I am familiar with and others that I am not. The parts that I am not familiar with are being chosen for different reasons, like manufacturer reputation, cost and functionality.
I am setting out to build a 117 CI" Twin Cam Engine I want to use the Fueling Cam Plate and Oil Pump but someone that I know had said that in comparison to the SE Cam Plate and Pump (Upgraded Version) that the Fueling set up is inferior. The following is what he had said,
"i wouldnt use either they are not a good set up the pump assemblys wet sump over night i dont like them and they are nothing but trouble stock plates with the pumps set up correct are awesome and no sumping! many of over 100 hp bikes out there with factory pumps and plates"
Does everyone have the same view as this or not?
So I need a Cam Plate and an Oil Pump. Which one should I use? An SE set up, a Fueling set up, or different one that I am not thinking of?
BlackDangerous is offline
post #2 of 8 (permalink) Old 06-09-2013, 09:37 AM
Hullhorr's Avatar
I went Feuling, but I read good things about the SE one as well. I don't think you can go wrong with either one.
Direct Harley Parts (forum sponsor) has the Fueling kit for $639.95. Best price I could find. It includes the cam chest, oil pump, lifters, and gaskets.
2009 FLTR MOP
Hullhorr is offline
post #3 of 8 (permalink) Old 06-09-2013, 09:46 AM Thread Starter
I am not interested in the lifters as I have a certain one that I will use. So in regards to what my friend is saying about the Fueling Plate, do you agree with this since you have a Fueling plate and pump?
post #4 of 8 (permalink) Old 06-09-2013, 12:19 PM
Hullhorr's Avatar
Can't answer that yet as mine is still in the box. Just got my bottom end back so I am reassembling today, but won't be up and running for a couple weeks probably. I have not read a single negative thing about the Feuling except for the price.
2009 FLTR MOP
Hullhorr is offline
post #5 of 8 (permalink) Old 06-09-2013, 01:31 PM Thread Starter
I would be very interested in getting your opinion about their performance when you get it up and running. He was saying something about the internal design of the Fueling Plate and kind of animated about it too. ?????? I agree, their stuff is not cheep at all.
post #6 of 8 (permalink) Old 06-09-2013, 01:47 PM
mocotom's Avatar
Cannot comment on the Fueling parts as I have never used them. I have used the newest version of the SE pump and plate on a couple bikes. I have had very good luck with this set-up and use it in my own bike. No sumping problems and oil pressure is 18lb at idle and 45 to 50lb at 2700 rpm with oil temp at 220*
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #7 of 8 (permalink) Old 06-09-2013, 02:18 PM Thread Starter
Cool. Not sure what his issue is with the Fueling stuff. That is pretty respectable oil pressure at idle without a spring upgrade.
BTW, I answered your question about my set up on my dyno post. Check it out.
post #8 of 8 (permalink) Old 06-12-2013, 09:36 AM Thread Starter
Thanks for the information. I do think that the Fueling Plate and Pump is going to be good to go. What lifters are included in the kit?
Use to use Mobil V Twin Syn Minivend Fluids and Lubricants 3 07-27-2015 11:23 AM
Zaino users which ones to use? Boxercop Paint & Bodywork Section 10 03-19-2013 09:54 PM
Phone Apps- Which ones you use the most? WorkhorseRG *General Road Glide Discussions/Pictures 19 02-04-2013 10:15 PM
Which Carb to Use BlackDangerous Engine Related 20 03-29-2012 07:29 AM
Which luggage to use nugzz *General Road Glide Discussions/Pictures 31 12-07-2011 11:57 AM
