Second time adjusting pushrods - Road Glide Forums
post #1 of 8 (permalink) Old 06-09-2013, 07:24 PM Thread Starter
X In Black's Avatar
During my cam install while putting the adjustable pushrods in, one of the the O-ringa on the back cylinder intake tubes fell off. Of course, I didn’t see it and continued with the install.
Long story short, since originally the lifters were full of oil and the adjustment called for 18-22 flats (I set them to 20), then wait 10 minutes, now that the oil has bleed out, do I do anything different the second time I adjust them?
My thinking is no. Set them for zero lash with my fingers, then adjust them 18-22 flats (Again, 20) and wait until they spin freely again, which could be right away, before moving on. Please correct me if I’m wrong.
I could kick myself...
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #2 of 8 (permalink) Old 06-09-2013, 07:27 PM
rageglide's Avatar
Exactly what you said. Get the lifter on the base of the cam, adjust the pushrod with your fingers to zero shake point, then turn it 20 flats and drink a beer... if it spins good to go, if not, another beer... ;-)
Hope you found it before you covered the bike with oil...
2012 fltrx
rageglide is offline
post #3 of 8 (permalink) Old 06-09-2013, 07:31 PM Thread Starter
X In Black's Avatar
Thanks rageglide. Yeah, I found it when I finished the front cyclinder and was putting the tubes in place on the rear. I'll never make that mistake again. Probably some other mistake, but not that one.
2012 FLTRX
post #4 of 8 (permalink) Old 06-09-2013, 08:56 PM
rageglide's Avatar
We all make mistakes, you got lucky. In fact it probably didn't get pumped up much at all. Most important thing is not spinning the motor over when the pushrod can't spin, might get lucky, but might be like a buddy of mine who bent valves on both heads ...
2012 fltrx
post #5 of 8 (permalink) Old 06-09-2013, 09:21 PM
piggs's Avatar
i once put a cam in upside down and readjusted the pushrods twice before i noticed that air was coming OUT the carb... that didnt seem right.
Piggs, SemperFi
2013 FLTRX Denim
piggs is offline
post #6 of 8 (permalink) Old 06-10-2013, 10:36 PM
SIG556's Avatar
Stock
I just stayed with the stock rods, no adjustment needed.
Back In Black!
SIG556 is offline
post #7 of 8 (permalink) Old 06-13-2013, 03:16 AM
Punishher7's Avatar
That requires you to remove the heads right?
2013 RGC
Punishher7 is offline
post #8 of 8 (permalink) Old 06-13-2013, 11:45 AM
rageglide's Avatar
No, only the upper rocker covers and rocker arm assemblies.
2012 fltrx
Right Speaker blew out second time now edimean22 Audio 10 07-04-2018 08:07 AM
I can't believe I dropped her a second time! Crazyhog *General Road Glide Discussions/Pictures 30 12-30-2013 12:27 PM
Engine light came on and speedometer went dead for the second time in 2 months Clean&Sober Troubleshooting for Road Glides 5 12-11-2013 04:14 AM
Second time around Jason707baggers Road Glide Builds-Document your builds HERE --NEW 10 03-29-2013 03:38 AM
Died again, for the second time. 07Roadie *General Road Glide Discussions/Pictures 11 11-07-2012 03:22 PM
