White smoke from engine ? - Road Glide Forums
 3Likes
post #1 of 12 (permalink) Old 06-23-2018, 04:58 PM Thread Starter
BeechRG's Avatar
I just had a majority of my bike powder coated and when I got it all pieced back together and started it up some white smoke came from the engine. The bike is a little low on oil but Iím hoping itís some of the powder coat warming up and burning off but seems unlikely. I also had the exhaust ceramic coated black but like I said the smoke was coming from the engine. The only thing I had powder coated in relation to the engine itself was the cam cover.
Anyone know what this could be ? I obviously am not riding the bike until I figure it out. Bike is a 2017 RGS
Thanks in advance.
BeechRG is offline
post #2 of 12 (permalink) Old 06-23-2018, 05:19 PM
lil chief's Avatar
My guess would be residual oil from the cam cover install, whether some dripped out of the cam chest and ran underneath the motor, or maybe you had some oil on your hands when you installed the cover. Could also be a cleaner if you used one after install.
Lil Chief
lil chief is offline
post #3 of 12 (permalink) Old 06-23-2018, 05:42 PM
norm9278's Avatar
Smoke from around the engine or the exhaust?
norm9278 is offline
post #4 of 12 (permalink) Old 06-23-2018, 06:36 PM Thread Starter
BeechRG's Avatar
Lil Chief
Thatís what Iím hoping for. Oil obviously came out when I removed the cam cover but the smoke seemed to be coming from the top of the engine. White smoke usually is only oil burning correct ?
BeechRG is offline
post #5 of 12 (permalink) Old 06-23-2018, 06:37 PM Thread Starter
BeechRG's Avatar
Engine. None coming out of exhaust
BeechRG is offline
post #6 of 12 (permalink) Old 06-23-2018, 09:27 PM
BlazingSaddle's Avatar
Did you catch a whiff of the smoke? That's usually the tell tale. White smoke could even be electrical, Everything has a distinct smell, like when dropped eyeglasses get wedged between the frame and the header for instance. Have you figured it out yet, and/or did it stop doing it? Any chance it could have been some residual on you PC'd parts?
BlazingSaddle is offline
post #7 of 12 (permalink) Old 06-24-2018, 12:43 AM Thread Starter
BeechRG's Avatar
I havenít figured it out yet. I pulled the bike out of the garage and started it up again. I couldnít see smoke this time (I was outside) but the returned and itís kind of mechanical? Idk how to describe it.
Iíve smelt burning oil or oil residue and it doesnít seem to be that exactly, however is similar.
I havenít made any modifications to anything internally and the only part of the engine Iíve exposed was the cam. I had a plastic bag over it to keep dust out while the cover was getting powder coated. Other than that I removed the exhaust and but nothing else that isnít cosmetic.
BeechRG is offline
post #8 of 12 (permalink) Old 06-24-2018, 06:18 AM
twowheeladdict's Avatar
I would recommend that you do the following with a cool engine. Put on a fresh pair of latex gloves and a new paper towel and run it around the engine everywhere you can reach and see if it picks up any liquid.
If the smoke looks like it is coming from the top of the engine you might want to remove the fuel tank so you have a better view.
It could just be burn off of something that got on the engine from the work you did. I would go over the list of what you removed to get the parts off and back on that were worked on. A bright light helps illuminate things you might not catch as well.
I wrapped pipes on a previous bike and there was a lot of smoke, but I knew what it was from and expected it. Not expecting smoke can be disconcerting.
madmat likes this.
twowheeladdict is offline
post #9 of 12 (permalink) Old 06-24-2018, 06:44 AM
RonC26's Avatar
Probably dumb suggestion - but was it taped down? Any chance there was a little tape or piece of bag left???
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #10 of 12 (permalink) Old 06-24-2018, 08:02 AM
Laconia's Avatar
Along with the other suggestions - make sure the air cleaner vent is not blocked - if it is it will blow a lot of white smoke.........
2017RGS, Vel Red, Stage IV, HD Performance Exhaust, HD Tuner, SuperShox Premium 14", HD Tall Boy Bars, Lepera Daddy Long Legs, HD Cool Fan, EZ-Up, 15" Smoke Windshield, Rear Saddlebag Guards, LED Lighting,Passenger Floor Boards, Whim,
Laconia is offline
Hello from the Great White North roadie25 New Members Welcome Area 17 03-08-2011 10:02 AM
Greetings from the Great white North UPNDWN68 New Members Welcome Area 14 03-05-2011 06:31 PM
2011 white glide Hotroadking Road Glide Specific Discussions 42 01-21-2011 02:53 PM
red, white, black TDavis *General Road Glide Discussions/Pictures 9 12-16-2010 09:09 PM
Inner fairing fading white on 09 motodrummer Troubleshooting for Road Glides 9 05-17-2010 06:53 AM
