SE 110 Bolt on Oil Upgrades? - Road Glide Forums
post #1 of 5 (permalink) Old 06-29-2018, 01:47 PM Thread Starter
mr4teth's Avatar
Question SE 110 Bolt on Oil Upgrades?
This past winter I had a SE 110 bolt on kit installed. I'm not that impressed with the power gains but that's beside the point. I've put a few miles on now and I have a few concerns.
1) The bike is extremely hot now in warm weather
2) Once hot the idle oil pressure is what I feel low .... 4-5lbs per my gauge. The HD dealer did check it and said it's normal. That maybe the case but I'm not comfortable with that.
I ordered a Harley oil cooler and heat tape for my headers to help with the heat but I was wondering what you think about adding a high volume oil pump to help with oil pressure.
2010 110 FLTRX
mr4teth is offline
post #2 of 5 (permalink) Old 06-29-2018, 02:54 PM
kouack's Avatar
Did you have it tuned by a professional? Or did only get the canned weak map from the stealer?
Envoyé de mon iPad en utilisant Tapatalk
kouack is offline
post #3 of 5 (permalink) Old 06-29-2018, 02:55 PM Thread Starter
mr4teth's Avatar
ThunderMax
2010 110 FLTRX
mr4teth is offline
post #4 of 5 (permalink) Old 06-29-2018, 03:36 PM
FDR's RGC's Avatar
Baisley oil spring. Increases oil pressure all the time. Raise mine to 10 psi when hot. Got 107 kit.
FDR's RGC is offline
post #5 of 5 (permalink) Old 06-29-2018, 05:47 PM
Brewiz's Avatar
I put the Axtell Oil Bypass in mine, at idle I'm at 10-15 and 50 at cruise. My builder put it back in my new oil pump when he built my motor.
Home :: Axtell TC Oil Bypass System :: Bypass System :: Axtell Oil bypass system
Brewiz is offline
110 bolt on Mpjonsey Dyno Results 6 04-05-2017 06:24 PM
SE 110 & MVA Fuel Moto 110 Drop in & 107 piston/cylinder kits now available fuelmoto Fuel Moto 0 03-16-2017 04:22 PM
HD 110 Bolt-on W/ GMR 577 cams and Dragos Stage 2.5 Heads sloride Engine Related 7 06-16-2016 07:27 AM
110 bolt on kit tjvazquez11 Engine Related 45 10-03-2015 08:49 PM
SE Stage 4 for SE 110" '13 CVO RG Batbiker Engine Related 2 01-19-2013 11:22 AM
