another oil from air cleaner on exhaust question - Road Glide Forums
 5Likes
post #1 of 25 (permalink) Old 07-04-2018, 06:36 PM Thread Starter
glidedawg's Avatar
good day all.... I have a 17 fltrxs with 10k on it and she is heading in for the 10 k service next week. Now, I've been getting oil from air filter from smog tubes onto my Bassani's, side cover and bag....
It used 1.5 quarts since last service, what should i tell/ask/ demand from service manager?
at one point I pulled the Air filter, manually open butterfly and saw oil pooled up in throttle body! I wiped her clean clean then rode her hard for 150 miles, oils back in there and the crew behind me said they smelled burning oil.
it was 96 here in Pa. ,humid as well. running synthetic H.D. oil as i bought the V.I.P.-E.S.P.
I can count on her getting sloppy after EVERY RIDE....OYYYYY
words of wisdom or experience greatly appreciated on how to deal with dealer, why does it do it?
Thanks to my fellow shark wranglers in advance.....
glidedawg is offline
post #2 of 25 (permalink) Old 07-04-2018, 09:04 PM
Harkon's Avatar
Riding hard makes it worse. To my knowledge some are worse than others for this. On my 103 TC I installed an external breather vent/catch can. Problem solved for me, but as this is emissions control doing so may affect your warranty.
2012 FLTRU, Alley Cat AC, Jackpot Super Duals header, Jackpot HiRoller Mufflers, PV Tuner || 2013 CRF450X FMF Powercore 4 HEX, uncorked, jetted
Harkon is offline
post #3 of 25 (permalink) Old 07-04-2018, 11:05 PM
JacktheBagger's Avatar
First thought is oil level , pre rushmores keep the oil half way up the hashmarks , and some will still blow by running hard ..
If you change it yourself use 3.5 qts , not four ..
eddienelson and geo8866 like this.
2011 Ultra
JacktheBagger is offline
post #4 of 25 (permalink) Old 07-05-2018, 03:53 AM
Thermodyne's Avatar
Get your drill and some nipples and a few feet of hose, plumb it down under the frame rail like an old bottom breather.
eddienelson likes this.
Thermodyne is offline
post #5 of 25 (permalink) Old 07-05-2018, 06:58 AM
mastergunnera8's Avatar
So.."another oil from air cleaner on exhaust question"..have you looked at the others?
Your saying you use 1.5 quarts since the 5K? dang..take it in and ask them about sumping
as others mention, 1/2 quart below the full on the stick...are you, or the dealer, using the incorrect fill line or using hot when cold or??
mastergunnera8 is offline
post #6 of 25 (permalink) Old 07-05-2018, 07:36 AM
Wood's Avatar
Using 1.5 quarts since last service is a lot of oil, especially with you seeing oil pooling in the throttle body after 150 miles. Something isn't right.
Wood is offline
post #7 of 25 (permalink) Old 07-05-2018, 07:50 AM
Little Wing's Avatar
Captain Obvious wants to know if it's a stock air cleaner.
When (what mileage or change was made) did it start puking oil?
Little Wing is offline
post #8 of 25 (permalink) Old 07-05-2018, 12:22 PM Thread Starter
glidedawg's Avatar
thanks all, it is a stage 1 s/e tune, bassani 2-1, hi flow a/c. i'm thinking of bottom breather type deal, BUT...warranty headache avoidance is 1 goal. Fixing the problem shall be the dealers goal?
I'm riding out to s.w. to see the sharks en-mas... and i don't want to carry oil cans dangit....
this sounds like sumping? oil pump issue? how do they fix the problem? thanks
post #9 of 25 (permalink) Old 07-05-2018, 12:24 PM Thread Starter
glidedawg's Avatar
sorry captain obvious, it always was stinky. after hi flow was installed i noticed the drool.... from the a/c, not me....
post #10 of 25 (permalink) Old 07-05-2018, 12:26 PM Thread Starter
glidedawg's Avatar
final oops, a/c was installed w/ other goods at 2500 miles
Oil Blow by at Air Cleaner Highway Troubleshooting for Road Glides 39 11-05-2017 11:33 AM
Oil From Air Cleaner Schmaxx Intake and Exhaust 6 09-19-2013 10:49 AM
Oil misting out my air cleaner....... jjyoung *General Road Glide Discussions/Pictures 7 09-08-2011 11:45 AM
Oil from SE air cleaner? dspencer Road Glide Specific Discussions 10 07-19-2011 01:00 PM
Oil coming out of SE Air Cleaner CSM11 Troubleshooting for Road Glides 10 07-04-2011 08:20 AM
