Low oil lamp / idiot light - 2018 M8 - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 07-05-2018, 01:48 PM Thread Starter
Beerme's Avatar
Yesterday I wanted to take a ride to a buddies house. I did my semi-normal ritual and checked the oil. "Full", and only about 300 miles since an Amsoil three hole change so I expected nothing less. Went to my buddies house, had a beer and shot the breeze yada yada yada.
I left and was on my second road home and happened to glance down to the dash to see my low oil idiot light on... I immediately push the information button and started looking for a safe place to pull over. Infotainment info has two dashes ( -- ) in place of the normal "OK".
Obviously I'm thinking the worst at this point, so once I get stopped I check the oil, feel around the oil and its obviously warm from circulation etc. etc. and can't find anything wrong.
So I did what you are never "supposed to do" and fired the engine back up. strangely it started right back up. No idiot light and Info says "OK". So I rode another 16 miles home with absolutely no issues. Started it up again today and no problems.
Think I have an issue or just a computer glitch?
2018 RGS
Husqvarna 701 Supermoto
Beerme is offline
post #2 of 19 (permalink) Old 07-05-2018, 02:40 PM
norm9278's Avatar
Jeez, remember when we used to go for a ride to relieve stress? Damn computers think they know everything!
Still under warranty, let the dealer make the call, and enjoy the ride.
kiwidave and Jacksprat56 like this.
norm9278 is offline
post #3 of 19 (permalink) Old 07-05-2018, 02:46 PM Thread Starter
Beerme's Avatar
Yes. I love shovelheads. If I could get a big inch shovelhead with a carb. I'd be all over it.
2018 RGS
Beerme is offline
post #4 of 19 (permalink) Old 07-05-2018, 02:54 PM
norm9278's Avatar
Had a ''69 FLH, got the tee shirt. Wouldn't go back for a daily rider though. Yep, you could fix damn near anything curbside, but on the other hand you usually had to! My twin cam is much more trouble free, but when trouble comes it takes more time to sort it out. Good luck with your M8, maybe one day I'll be able to afford one!
norm9278 is offline
post #5 of 19 (permalink) Old 07-05-2018, 03:46 PM
Laconia's Avatar
No you may have a problem - check your ECM code - they've had a few issues and may have to replace your oil pump - mine was done - happened as yours did - if you find a PO522 or PO523 do not clear the code and advise the dealer ASAP....
2017RGS, Vel Red, Stage IV, HD Performance Exhaust, HD Tuner, SuperShox Premium 14", HD Tall Boy Bars, Lepera Daddy Long Legs, HD Cool Fan, EZ-Up, 15" Smoke Windshield, Rear Saddlebag Guards, LED Lighting,Passenger Floor Boards, Whim,
Laconia is offline
post #6 of 19 (permalink) Old 07-05-2018, 04:40 PM Thread Starter
Beerme's Avatar
I just now learned how to check diagnostics... Infotainment shows no logged DTCs. So that's either good news or I did it wrong, but I know for a fact I did not clear anything.
2018 RGS
Beerme is offline
post #7 of 19 (permalink) Old 07-05-2018, 04:58 PM Thread Starter
Beerme's Avatar
Correction. I did it with the ODO button and have an ECM code P0523 - PN001349-01
Trying to figure out what that is exactly
2018 RGS
Beerme is offline
post #8 of 19 (permalink) Old 07-06-2018, 01:58 PM
norm9278's Avatar
The P0523 code is related to oil pressure. Get the dealer to check it out. Could be a wiring or sensor issue but let them deal with it. They might even send a truck to pick it up once you describe the issue.
norm9278 is offline
post #9 of 19 (permalink) Old 07-06-2018, 04:56 PM Thread Starter
Beerme's Avatar
Dealer says:
"You have an 18, so you have the new oil pump"
"Its a history code. "Could have happened from a backfire or anything"
PO523 is very clearly an oil pressure code...
"If it happens again, we will replace the sender"
I asked if they scoped the cylinders... "No, we see no need to. Non-issue" (pretty much blew me off like they had no time for my situation)
I want this to be true (no issue), but found the lack of interest or caring to be frustrating. This dealer will get no more of my business. This is a hard bike for me to afford and they treat the situation like they have no time for it. Handed me my keys and pretty much said have a nice day. Last time I darken their door.
I miss my old dealer that retired and shut...
2018 RGS
Beerme is offline
post #10 of 19 (permalink) Old 07-06-2018, 06:04 PM
ChromeSpark's Avatar
Dealer says:
Who's the dealer, don't want to stumble in there by mistake!
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
2018 audio upgrade - low budget option? georgec Audio 149 09-25-2019 09:51 PM
M8 low transmission fluid ameleo Fluids and Lubricants 12 08-12-2019 01:19 PM
Low transmission fluid in M8 2016CTRoadGlide Engine Related 14 06-22-2017 02:38 PM
NO OIL and no idiot light?? motodrummer Troubleshooting for Road Glides 16 06-18-2015 09:48 PM
Woods TW-777 cams low low miles pat123 Parts for Sale 8 04-16-2014 05:20 PM
