prim chain tensioner - Road Glide Forums
 2Likes
  • 1 Post By ironmark
  • 1 Post By PeteF
post #1 of 7 (permalink) Old 07-15-2018, 03:37 PM Thread Starter
StGhost's Avatar
Getting ready to install a new Baker Compensator. Which chain tensioner should I use?
Stock (HAVE)
Hayden (HAVE)
Baker armored Attitude adjuster(NEED TO BUY)
StGhost is offline
post #2 of 7 (permalink) Old 07-15-2018, 04:31 PM
Mike U's Avatar
StGhost, I had the Hayden and it was very tight and cut grooves into the shoe.
I have since changed that out for The Baker Armored Tensioner and am very pleased with it. I like the fact that it is adjustable where the Hayden is not.
Hope this helps.
Best of Luck.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #3 of 7 (permalink) Old 07-15-2018, 05:01 PM
Dragon Dude's Avatar
I also have the Baker Attitude tensioner and it does great so far. I've had mine on there for about a year and no problems yet.
Dragon Dude is offline
post #4 of 7 (permalink) Old 07-16-2018, 10:47 AM
Woodman's Avatar
Ran A Hayden for 60,000 miles no problems.
Woodman is offline
post #5 of 7 (permalink) Old 07-16-2018, 11:46 AM
There is nothing wrong with the stock tensioner. I have used the Hayden too and to me the chain seemed to be to tight so I put the stock tensioner back in. You really don't want to go with a manual adjuster because you need to remove the entire primary cover just to do a simple adjustment. I have over a 100,000 miles on my bike and most all the miles were with the stock tensioner and I haven't had any issues. I also run the Baker Compensator.
RGKen likes this.
post #6 of 7 (permalink) Old 07-16-2018, 12:16 PM
I'll repeat what ironmark said. There's nothing wrong with the stock tensioner. I just pulled my primary cover at 25,000 miles to check it and there was almost no wear.
RGKen likes this.
PeteF is offline
post #7 of 7 (permalink) Old 07-16-2018, 01:48 PM
I've also put over 100k forward miles on FLTRI with the same stock pri tensioner and runs fine. simple math will add 3,750 fugitive miles to your bike/yr ..... ex: add idle time of 15min/day for 5 days/week, 1.25 hr/wk x 50wks/yr = 62.5 hr/yr ~ so if you were going 60 mi/hr for 62.5 hrs you'd add 3,750 fugitive (non-forward) miles to your bike/yr not including burnouts
reds4 is offline
cam chain tensioner cyclejuice Engine Related 7 05-30-2013 04:53 PM
Hydraulic chain cam tensioner kit ohd24 Engine Related 7 06-30-2012 07:24 AM
Chain tensioner Jerry W. Engine Related 4 06-29-2012 08:09 PM
Cam chain tensioner question SKULLZ *General Road Glide Discussions/Pictures 5 05-14-2011 02:29 PM
