Oil temp with hard running - Road Glide Forums
post #1 of 25 (permalink) Old 06-14-2013, 08:21 AM Thread Starter
rob883's Avatar
What temp should my oil be at running hard and high heat in Florida ?
1969 XLCH sold 1972 XLH sold 2002 Dyna Defender
2002 Ultra Electra Glide sold 2013 RoadGlide Ultra
1986 FXRD great bike !!
rob883 is offline
post #2 of 25 (permalink) Old 06-14-2013, 08:30 AM
tdkkart's Avatar
"Design" oil temp on the Twin Cam motor has often been reported to be 230* which is a pretty normal number that youll see after 20mi of highway riding in 75-80* weather. Ive seen 250 or so in 100* temps. Temps in stop and go traffic can be higher.
tdkkart is offline
post #3 of 25 (permalink) Old 06-16-2013, 09:32 PM
I live in Tallahassee and just rode up and back to Greensboro, GA. I had the dealer install a Reefer oil cooler and a HD factory oil guage.
On I75 at 75-80Mph during the late morning, bike ran at 205-210 deg. We got stopped in traffic for a few and were going nowhere fast for 3 miles. Bike quickly jumps to 230. It did not get any hotter. I did, however!
On return trip, in the cooler am temps, bike ran about 190-200 down same stretch of I75. Hit traffic back home and back to 230.
You can park bike for lunch and return and these engines will drop 50 deg in an hour. Amazing.
Just a real case example. I hope this helps.
JSFRGU is offline
post #4 of 25 (permalink) Old 06-16-2013, 10:26 PM
tmd
On the newer 103 Twin Cams 230-260 is normal. In 100 plus temps and stop and go traffic 280-300 is normal.
tmd is offline
post #5 of 25 (permalink) Old 06-16-2013, 10:30 PM
If you didn't have the Reefer, you would see the temps go a bit higher, I know because I had my oil temp gauge before I bought my reefer, for extra cooling you might also want to try engine cooling fans. BTW welcome to the forum from Miramar.
post #6 of 25 (permalink) Old 06-16-2013, 10:33 PM
+1... I had the same concerns when i installed the oil temp gauge. It was comfirmed that the twin cams will and do run temps up to 300°.
post #7 of 25 (permalink) Old 06-16-2013, 11:02 PM
ChivoChavez321's Avatar
Pretty much as stated above.....did 800 miles across northern NM and back doing speed limit plus 5. When relatively cool, 200-215, warmer temps above 85, around 220 with an occasional 230.
2013 Big Blue Pearl Road Glide Ultra. Monster Ovals, Jackpot Ceramic Headers, Fuel Moto Power Vision and Billet Air Cleaner, Oil Temp guage, saddle bag bumpers, 11.5" rear progressives 444, monotubes -1, Woods TW-777 cam 107 FM kit with Level B Heads, polished throttle body. 123 Torque/113HP. "Lord, help me to be half the man my dog thinks I am"
ChivoChavez321 is offline
post #8 of 25 (permalink) Old 06-16-2013, 11:16 PM
May I add that I understand 250 plus is normal, but I still am gonna get a slight "pucker factor" when I see 250 plus going to Shark Week III.
post #9 of 25 (permalink) Old 06-17-2013, 05:32 PM
prodrag1320
Guest
Posts: n/a
anything above 250,ide pull over & let it cool off (or get a better cooler)300,forget it,WAY TOO HOT,IMO
post #10 of 25 (permalink) Old 06-18-2013, 06:49 AM
Sumax the powder coating folks, that we have built MANY bikes for, locally, had us perform some cylinder head heat testing for them about 10 years ago in our oven we use when we used to(still do occasionally)re-sleeve cylinders.
At a digital recorded 350*, the valve seats WILL start to migrate in the head, FWIW.
Scott
Hillsidecycle.com is offline
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 07:42 AM
Engine oil temp? At what temp do you pull over? Mountainman Fluids and Lubricants 35 07-07-2015 04:47 PM
Just wondering who running radial tires and who is running bias. Pros and cons please scsharp2260 Wheels and Tires 8 08-11-2013 08:20 AM
Alas..oil temp issues lp_ *General Road Glide Discussions/Pictures 10 08-23-2010 06:37 PM
Lower your oil temp by changing your oil...??? dklanecky Do-IT-Yourself 14 07-07-2010 10:29 PM
