Love Jugs v fan assist oil cooler - Road Glide Forums
 5Likes
post #1 of 15 (permalink) Old 07-27-2018, 12:45 PM Thread Starter
Hi,
After a sucky traffic jam last weekend I'm looking into additional engine cooling for my 2018 RG. Does anyone know which of the following is more efficient for low speed/stop and go traffic?
Harley "Cool Flow fan"
Love Jugs
Harley fan assist oil cooler
Thank you
Dave
sailronin is offline
post #2 of 15 (permalink) Old 07-27-2018, 01:00 PM
Love Jugs or any other fan that mounts on the left side (Lenale, etc), is going to blow air across the fins and help cool the engine. Only problem is that hot air is just going to end up on your right leg. These products DO work to help cool your engine and make the bike run better and last longer, but they don't make much difference in rider comfort.
The Fan assist oil cooler is in the same boat. It will help keep the heads cool, but you are still going to feel heat in stop and go traffic.
The Cool Flow Fan is going to be the most noticeable change in rider comfort. It pulls the heat away from the rear cylinder and exhausts it down, away from the rider. The kit with the fan/triple tree button/cutout heatshield makes a nice package on the '17+ touring bikes. I'd have one in an instant if I had an M8! Unfortunately, there is not a kit to adapt to my '15 103HO. I know there have been a couple folks that have rigged it to work on 2015-2016 bikes, but I am NOT electrically inclined enough to attempt it.
geo8866 likes this.
macabra11 is offline
post #3 of 15 (permalink) Old 07-27-2018, 02:07 PM Thread Starter
Thank you,
I'm not as worried about my leg as the health of the engine. Just ordered a pair of Love Jugs so I'll see what happens in hot stop and go.
Best regards,
Dave
post #4 of 15 (permalink) Old 07-27-2018, 02:19 PM
Wood's Avatar
Originally Posted by sailronin View Post
Thank you,
Best regards,
Dave
Hope you have a plan to take real temperature data before and after the Love Jugs. Or are you going with more anecdotal 'seat of pants' (my leg is really hot) measurements?
Wood is online now
post #5 of 15 (permalink) Old 07-27-2018, 02:24 PM
Laconia's Avatar
Cool flow works well on mine - the Love Jugs do an excellent job as well - I was not a fan of the jugs appearance - so I went with the Cool Flow, I set mine on automatic and never think about them until I stop that's when I appreciate it....
2017RGS, Vel Red, Stage IV, HD Performance Exhaust, HD Tuner, SuperShox Premium 14", HD Tall Boy Bars, Lepera Daddy Long Legs, HD Cool Fan, EZ-Up, 15" Smoke Windshield, Rear Saddlebag Guards, LED Lighting,Passenger Floor Boards, Whim,
Laconia is offline
post #6 of 15 (permalink) Old 07-27-2018, 02:30 PM
Thermodyne's Avatar
The mighty might from love jugs is what I would recommend. It basically the old Wards set up, which was prolly to most efficient set up around. Why else would LJ litigate the rights to it away from Ward.
No idea as to what flavor of Roadie you have, but assume it must not have water cooling. So it would benefit greatly from jug fans. And it would prolly benefit some from more air over the oil cooler.
I have a set of old Wards fans on my 11, and can basically idle in traffic indefinitely. Added an fan assisted oil cooler when I pushed it out to 110, and while it does hold the oil temps in the reasonable range, its apt to come on any time, not just in traffic.
RGKen likes this.
Thermodyne is online now
post #7 of 15 (permalink) Old 07-27-2018, 06:41 PM Thread Starter
I have the lcd oil dipstick temp gauge so will check with that once the fans are installed.
Mine is not liquid cooled so it's air and oil that keep the engine from overheating. The 2018's come with an oil cooler (not fan assist) but reading the various threads it seems cooling the heads will be the most efficient means to keep everything cooler. I don't understand why Harley doesn't deliver the touring bikes with a fan assisted oil cooler??
post #8 of 15 (permalink) Old 07-27-2018, 09:31 PM
1: Because there are a lot of Harley dinosaurs out there (and on this forum) that don't want anything new or electric and 2: How are they going to sell you one if you already got one on the bike? (This is probably the most important reason, in my opinion.)
flint and sailronin like this.
judgedelta is offline
post #9 of 15 (permalink) Old 07-29-2018, 06:08 PM Thread Starter
I'll go with part 2, MOCO wants the money. As to part 1, Harley has had fuel injection and fly-by-wire longer than almost any mfg and the purists stopped kicking about that long ago.
post #10 of 15 (permalink) Old 07-29-2018, 07:33 PM
Thermodyne's Avatar
No idea as to why the MoCo is reluctant to put additional cooling on these scooters. But I suspect that adding the cooling would be seen as admitting that they are under cooled.
With that said, the fuse panel on my 11 has an empty slot marked "Fan". So even back then they had some plans for adding a fan.
Jug fans make a huge difference. You can keep the head temps almost as cool sitting still, as they are at 60mph. The oil cooler fans are more about the oil life, as opposed to cooling the motor. The Reefer I'm running holds the oil a little under 260f according to the gauge. But the fan light does not mirror the gauge. The fan cuts on and off over time, with no change shown on the gauge. I suspect that the gauge is showing some trans heat on the highway, being in the pan attached to the trans. And the cooler fan reads oil temp at the filter housing.
Brewiz likes this.
Love jugs vs fan assisted oil cooler Lima14 Aftermarket Accessories 15 01-07-2019 09:43 AM
Fan assist oil cooler for 2015 road glide Speedy540 *General Road Glide Discussions/Pictures 4 05-30-2018 08:44 PM
Jagg fan assist oil cooler Darreldanger Engine Related 5 05-27-2014 02:23 PM
Jagg 10 row fan assist vs Ultra-Cool oil coolers longrides *General Road Glide Discussions/Pictures 27 07-05-2013 02:42 PM
Ultra Cool RF-1 Fan Assist Oil Cooler - Black Powder coat longrides Parts for Sale 8 05-03-2013 11:32 AM
