M8 owners - Oil consumption? - Road Glide Forums
 22Likes
post #1 of 60 (permalink) Old 08-12-2018, 10:32 AM Thread Starter
Please only M8 experience replies - other threads on internet forums I saw on this issue deviate quickly from the question. I am very curious to hear facts from you other M8 owners as to are YOU having any Oil consumption issues --- OR --- are you Not seeing this with your M8?
This post is pre-dealer visit as its Sunday and just returned from long trip. This my 4th RG in 20 years, I do ride pretty hard and long trips often but never had a Harley burn oil in all those years till this M8.
My story ......bike is 2018 RG Ultra, had dealer add Stage 2 Cam kit before I drove it home. Had 1000 mile service done. Then multiple day trips and at 1850 miles I checked and fluids were perfect level. Just returned from a 3535 mile trip over 13 days, and consumed 2+ qt. oil & 3.5 oz. trany fluid!!! Rode thru Idaho, Yellowstone then to Deadwood for rally. I never rode it in hot part of day, 55F to 90F riding temps the whole trip. Yea I read all the transfer fluid issues that's why I have been checking trany too.
I "check" oil as per manual, run for 2+ minutes then turn off and check on jiffy stand. Sometimes run bike for 10-15 minute ride before checking.
I checked oil after 1650 mi. (3500 mi. odometer) and was 1 qt. low and added the qt. Added and re-checked next morning and all good. Trany looked just below mid range so left as-is.
Checked oil after ~900 mi. more and was ~1/2 qt. low so added and rechecked cold next morning, all good. Trany looked OK still.
Go home yesterday, checked and clearly 1/2 Qt. low so added it, then checked trany and was way low... added 8 oz. I rechecked both cold just now and ok, but still little low on oil, trany back to good level. .
I am so very happy with this bike, best ever in so many ways, but extremely concerned if and what may be wrong here.
TennesseeRoadGlide likes this.
Last edited by Idaho-Cal RGU; 08-13-2018 at 09:58 AM. Reason: corrected numebrs after measuring volume left in qt. & explained engine oil chekc procedure.
Idaho-Cal RGU is online now
post #2 of 60 (permalink) Old 08-12-2018, 10:45 AM
Little Wing's Avatar
sorry for your troubles, man.
i have an '18 FLTRX with 4800 miles and no issues so far. i'm loving this engine.
mfg. date 04/18
definitely take it in for dealer info.
more people will chime in i'm sure.
Little Wing is offline
post #3 of 60 (permalink) Old 08-12-2018, 12:11 PM
rider17's Avatar
Had some initial oil leakage before the 1k service. Replaced an o ring. Had some more leakage that my new dealer finally diagnosed as the fact the old dealer overfilled the bike. Started running it mid range and it has been solid since.
2017 Road Glide Special Denim Black
If the path be beautiful, let us not ask where it leads - Anatole France
rider17 is offline
post #4 of 60 (permalink) Old 08-12-2018, 01:13 PM
tomwhall's Avatar
I purchased my 2018 FLTRXS in August of 2017. Only 7k miles, but I've had no problems with engine or trany oil.
tomwhall is offline
post #5 of 60 (permalink) Old 08-12-2018, 02:00 PM
twowheeladdict's Avatar
Sorry to hear. Hopefully they can get it figured out and fixed under warranty.
I have had no issues with my '17 M8 Road King, and no issues with my '18 Road Glide Special.
I don't know about the Harleys, but many of the metric bikes I have owned stated in the owner's manual that it was normal to consume oil with sustained high speed riding.
RGKen likes this.
twowheeladdict is offline
post #6 of 60 (permalink) Old 08-12-2018, 02:29 PM
HellInABucket's Avatar
There is a technical bulletin out, which I have personally read. It says 1QT every 1500 miles is normal.
I am not making this up.
HellInABucket is online now
post #7 of 60 (permalink) Old 08-12-2018, 03:07 PM
I have a 17 RGS that burned a quart and a half on a 3300 mile ride this summer. We were running through the Nevada desert at 75-80 with ambient temperatures at 95-105. Never really noticed any consumption with all the local day rides. I did just switch to synthetic before the trip. 9700 on the odometer.
jerrod75 is offline
post #8 of 60 (permalink) Old 08-12-2018, 03:21 PM
glide69's Avatar
I have 18k on mine no issues just returned from Shark Week and that was a 6,921 mile trip and the tranny oil was still on the same mark as when I left...
eddienelson likes this.
2018 FLTRXS Wicked Red
glide69 is offline
post #9 of 60 (permalink) Old 08-12-2018, 04:08 PM
geo8866's Avatar
Your 8 ounces of tranny fluid might be the transfer issue. You didn't mention if you checked the primary to see if it migrated. (Check it)
I did have to add about a quart of oil after about 3k. I also have stage 2 (torque cam). I occasionally get blow by (screamin' eagle ventilator air filter) if I ride hard so I could have lost oil that way.
dmrdn and RGKen like this.
geo8866 is offline
post #10 of 60 (permalink) Old 08-12-2018, 04:54 PM
madmat's Avatar
I added 1.5 qts between 2200-4800 miles. Have not added any in the last 1k miles, currently 5800.
18 RGS Bonneville Salt Pearl
madmat is offline
M8 oil consumption ia15rgs Engine Related 13 06-06-2017 03:30 PM
Excessive oil consumption Mr. E Troubleshooting for Road Glides 10 09-25-2012 08:41 PM
Excessive oil consumption? 1st Sgt Troubleshooting for Road Glides 8 08-21-2012 09:59 AM
Oil Consumption/ Compression & Brakes? TearlessTom Troubleshooting for Road Glides 18 11-06-2011 06:11 AM
Oil Consumption Crazyness road-king *General Road Glide Discussions/Pictures 9 03-31-2011 07:51 PM
