Engine hesitation/bucking feeling - Road Glide Forums
 3Likes
post #1 of 14 (permalink) Old 08-25-2018, 02:51 PM Thread Starter
Have 2012 road glide and have an issue when just starting out to ride motorcycle.
Motorcycle has hesitation/Bucking feeling until it is warmed up and I have been riding for about 10 miles.
I have replaced the following: Spark plugs, wires, air cleaner, cleaned out fuel tank, fuel check valve assembly, engine temp sensor, fresh gas (3 tanks).
Motorcycle has throttle response, starts fine, great idle.
I am at a loss here. Would like to be able to fix myself and not have to take it to the dealer $$$$.
Any help would be appreciated.
T.Davis
5150roadglide is offline
post #2 of 14 (permalink) Old 08-25-2018, 02:55 PM
Clutch1's Avatar
Running premium fuel? 87 octane will do that to mine.
04 Road Glide
Clutch1 is offline
post #3 of 14 (permalink) Old 08-25-2018, 02:59 PM Thread Starter
I only run 91 octane.
post #4 of 14 (permalink) Old 08-25-2018, 03:46 PM
Smarty's Avatar
You might look for intake gasket leak and the other thing is to clean the IAC just inside the throttle body looking up. Use some Berryman carburetor cleaner with the straw on it. That should help
2016 RGS Black Quartz
Smarty is offline
post #5 of 14 (permalink) Old 08-25-2018, 04:08 PM
RGKen's Avatar
His bike is a 2012 and has TBW thus there is no IAC.
2018 FLTRXS
RGKen is offline
post #6 of 14 (permalink) Old 08-25-2018, 04:51 PM
smitty901's Avatar
First thing pull the codes.
smitty901 is offline
post #7 of 14 (permalink) Old 08-27-2018, 03:57 PM
Smarty's Avatar
Good point, didn't notice the year! Good catch Ken!
RGKen likes this.
Smarty is offline
post #8 of 14 (permalink) Old 08-30-2018, 08:27 PM
ButchS's Avatar
T.Davis
Maybe check the wire connectors to the throttle body? Could be a cracked or broken one in the pins to the throttle body. Can be difficult to tell and not real common but not uncommon.
Just a thought!
ButchS is offline
post #9 of 14 (permalink) Old 08-30-2018, 09:13 PM
ButchS's Avatar
Just a thought!
Another thing to check is (not sure what the part name is) but the mass air flow sensor or air temp sensor at the throttle body.
ButchS is offline
post #10 of 14 (permalink) Old 09-05-2018, 10:13 PM
I would check for an intake seal leak. Not uncommon and they are just rubber gaskets. If you’ve messed with the throttlebody any time recently, loosened the bolts holding the throttlebody, it could have shifted.
Do you have any codes shown in a WOW test? If so; what are they?
Also, I’ve seen a rash here lately of bad O2 sensors. Just a thought but they will typically throw a code.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
Engine bucking, stalling, high idle, sputtering Taccone *General Road Glide Discussions/Pictures 31 02-23-2018 09:34 PM
Bucking at steady throttle 3609Glide ECM/Fuel Management systems 13 05-10-2014 02:00 PM
Momentary Hesitation (Hiccup) bbass ECM/Fuel Management systems 11 08-08-2013 03:46 PM
Momentary Hesitation (Hiccup) bbass Troubleshooting for Road Glides 1 07-19-2013 06:11 PM
Starter Hesitation & Fuel Range reading Cotton Hill Troubleshooting for Road Glides 4 05-27-2011 08:37 AM
