103HO Vibration - Road Glide Forums
 10Likes
post #1 of 17 (permalink) Old 08-29-2018, 11:42 PM Thread Starter
Bucky4835's Avatar
103HO Vibration
Not sure if this will be helpful or not but it seemed to take care of a vibration I had that was driving me crazy. My 16 RGS has 8200 miles on it and it had this vibration that started about 1500 miles ago. It would come in and be noticeable between 2500 and 3000 rpms and it would go away if I pulled in the clutch. I could feel it in my handlebars and my left mirror would vibrate where vehicles behind me were blurry. I checked tires, wheel bearings, and exhaust for loose or bad parts. Besides my rear tire starting to cup, I could not find anything else wrong but the vibration was still there. I looked at the motor mounts and they looked good. I then inspected the engine stabilizer. I found it to be stuck and not able to rotate freely and it was twisted and stuck rolled forward, if that makes sense. The bar was not able to twist on the ball joints. I checked the torque and that was fine. I did lube the ball joints on both ends and freed up the shaft so it could rock back and forth by hand where before it was dry and stuck. I took the motorcycle out to see if it took care of the vibration and it was gone. It rides as smooth as it ever has. Not totally sure why except it was transferring the engine vibration straight into the frame since it seemed to be in a bind.
Jim
2016 RGS Superior Blue
Bucky4835 is offline
post #2 of 17 (permalink) Old 09-10-2018, 05:22 PM
Jim
Thanks for posting this
My '16 RGU developed the same vibration the day after riding about 8hrs in the rain on the way to Sturgis this year. I checked my stabilizer and as you stated mine was stuck. I had to use a flat head screwdriver to free it up. Its raining here so haven't had a chance to ride it yet.
conn-e-rot is offline
post #3 of 17 (permalink) Old 09-10-2018, 05:32 PM
eddienelson's Avatar
You da man!!! I just checked mine and its a little stiff. No vibrations yet but It does need to be lubed.
2016 RG Custom Vivid Black
eddienelson is offline
post #4 of 17 (permalink) Old 09-11-2018, 08:41 AM
Anyone have a photo of the area in question? Where to lube?
geo8866 likes this.
macabra11 is offline
post #5 of 17 (permalink) Old 09-11-2018, 10:01 AM
geo8866's Avatar
That would definitely be helpful if you could show the exact area you're speaking of. Thanks
geo8866 is offline
post #6 of 17 (permalink) Old 09-11-2018, 08:24 PM
chowman63's Avatar
I was thinking the same thing. Need a picture of the area we are talking about. Pretty sure I know, but just a confirmation would be great. And what are we lubing it with?
chowman63 is offline
post #7 of 17 (permalink) Old 09-11-2018, 08:56 PM
Front cylinder top to the frame. Its a rod with a heim joint on each end. Ones attached to the engine the other to the frame. https://www.wisconsinharley.com/harl...dels-16400020/
post #8 of 17 (permalink) Old 09-12-2018, 12:36 AM Thread Starter
Bucky4835's Avatar
Thanks for posting the link to the part I was referring to. The only thing I can think of is if the link is stuck and canít freely move, it doesnít have a chance to absorb the vibration. I will take some pics tomorrow and show the position mine was stuck in. It would probably make more sense as to what I am trying to explain. Lol
Jim
post #9 of 17 (permalink) Old 09-12-2018, 12:39 AM Thread Starter
Bucky4835's Avatar
At this point, I just used some Break Free CLP. Silicone spray lubricant would probably work but I would imagine it would dry out faster.
chowman63 likes this.
post #10 of 17 (permalink) Old 09-12-2018, 03:30 PM
wevsspot's Avatar
What did you lube the joints with?
wevsspot is offline
103HO SE 255 Cams Bucky4835 Engine Related 19 02-13-2018 02:03 PM
bad vibration on the decel!!! Help!!! shimo Troubleshooting for Road Glides 12 05-31-2011 05:29 PM
Bag vibration NakedSnowman Troubleshooting for Road Glides 3 05-09-2011 12:53 PM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 10:59 AM
Floorboard Vibration jcanrun *General Road Glide Discussions/Pictures 4 03-14-2011 02:04 PM
