2019 Road Glide Ultra 114 cams - Road Glide Forums
 6Likes
post #1 of 15 (permalink) Old 09-03-2018, 01:37 PM Thread Starter
Prolific's Avatar
Question 2019 Road Glide Ultra 114 cams
The new 2019 Road Glide Ultra comes with a 114 Milwaukee-Eight. So, which cam is in the engine? Previously, the 107 Milwaukee-Eight could get a torque or power cam as a Stage II. And the Stage III and IV kits would bump up the engine size to 114, with new cams in each kit.
So, now I'm curious. With the RG Ultra starting at 114, does it have the Stage III cam (SE8-498)? Or does it still have the original cam that comes in a stock 107? or something else?
On the same note, is this 114 engine essentially a Stage III without a tuner, pipes and air cleaner?
With the new RGU purchase, I know I need a new air cleaner and new pipes (and tuner). I was thinking I would get the Stage II torque cams as well, but not if the Stage III cams are already in the 114.
ksbutler44 likes this.
Prolific is offline
post #2 of 15 (permalink) Old 09-03-2018, 07:06 PM
107s and 114s use the same cam in stock configuration. The CVO 117 cam is the same as the Torque cam, just a different part number. I’m getting ready to put some new, take-off 114 cylinders and pistons on my Glide with a CVO 117 cam. I’m in essence making a stage 3 kit with without the 498 cam and valve springs.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 15 (permalink) Old 09-03-2018, 08:51 PM
Good question I was wondering the same thing.
Sent from my SM-G955U using Tapatalk
ksbutler44 is offline
post #4 of 15 (permalink) Old 09-03-2018, 09:49 PM
No it has some epa crappy stock cam.
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #5 of 15 (permalink) Old 09-03-2018, 09:50 PM
Originally Posted by crazy4ink View Post
107s and 114s use the same cam in stock configuration. The CVO 117 cam is the same as the Torque cam, just a different part number. Iím getting ready to put some new, take-off 114 cylinders and pistons on my Glide with a CVO 117 cam. Iím in essence making a stage 3 kit with without the 498 cam and valve springs.
Not sure that will work. The 114 from the factory is not the same as the stage 3 114.
geo8866 and ksbutler44 like this.
post #6 of 15 (permalink) Old 09-03-2018, 09:52 PM
The stock 114 gets its cubic inches from more stroke not bore size. If I am wrong somebody will correct me.
geo8866 likes this.
post #7 of 15 (permalink) Old 09-03-2018, 10:13 PM
Bruce00's Avatar
You are 100% correct.
107 stroke is 4.375 & bore of 3.937
and the 114 has a stroke of 4.5 with a 4.0 bore
geo8866 likes this.
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #8 of 15 (permalink) Old 09-03-2018, 10:16 PM
I thought so but wanted someone with mor knowledge to back me up on that.
post #9 of 15 (permalink) Old 09-04-2018, 04:29 PM Thread Starter
Prolific's Avatar
But is this 114 on the 2019 Road Glide Ultra, the same as the previous M8 Stage III 114?
Does anything from the previous years' M8 Stage III kit come on the Road Glide Ultra (valve springs, tappets, etc)?
From what it sounds like, it's almost the exact same as the stock 107. Same cams and other hardware, just with a little more stroke and a slightly bigger bore.
Prolific is offline
post #10 of 15 (permalink) Old 09-16-2018, 06:49 AM
MyGlide's Avatar
No, its just bigger.
2018 KTM Super Duke R
MyGlide is offline
Stage III upgrade from 107 to 114 available Ohiobellboy Engine Related 26 12-23-2017 09:14 PM
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
cams,cams,cams dozer23 Engine Related 2 03-03-2017 08:18 AM
Ordered the 114 big bore kit for the new 17 RGU masterblaster *General Road Glide Discussions/Pictures 8 09-16-2016 11:45 PM
