Stage 3 114 destination problems - Road Glide Forums
 14Likes
post #1 of 24 (permalink) Old 09-04-2018, 05:25 PM Thread Starter
Took a 1000 mile ride for the Holiday weekend. IL MO Ark TN Ky. The bike runs fine as in power wise but man it has huge problems with pining, spark knock. So loud going down the interstate I could hear it over the radio. Sounds horrible! Gets even louder when I get in the gas hard. Stage 3 114 with the Harley Smart Tune Pro installed. I though the smart tune was so supposed to eliminate problems like this. I am pretty sure itís running lean and getting to hot. The oil is clean and doesnít load ok burned or like itís been hot and the bike has a shit load of power. I have kinda eliminated the possibility of sumping causing the heat. Anyone have any ideas. To much timing or running to lean causing it to run hot ?
2016 Road Glide Ultra Superior Blue
freedom1974 is offline
post #2 of 24 (permalink) Old 09-04-2018, 05:26 PM Thread Starter
I meant detonation problems. Damn phone.
post #3 of 24 (permalink) Old 09-04-2018, 05:33 PM
Was it tuned or are you hoping the H-D device will eventually sort things out?
Eddie Haskell is offline
post #4 of 24 (permalink) Old 09-04-2018, 05:34 PM
dieselshadow's Avatar
Are you using premium high octane fuel? Regular grade will cause these issues in a normal air cooled heavy twin in hot weather, let alone a performance minded engine.
2013 FLTRU
dieselshadow is offline
post #5 of 24 (permalink) Old 09-04-2018, 05:37 PM Thread Starter
The auto tuner has been on there since 300 miles. Bike has 5000 on it now. It was tuned with the SE street tuner after the build then the smart tune pro was added.
post #6 of 24 (permalink) Old 09-04-2018, 05:38 PM Thread Starter
Running 93 octane in it. It was hot this weekend but I have had a number of built motors and none of them spark knocked like this one ever.
post #7 of 24 (permalink) Old 09-05-2018, 11:08 AM
BH#103's Avatar
Recheck the map, maybe the auto tune is at its limits and can't make further adjustments.
geo8866 likes this.
"SLIVER"
BH#103 is online now
post #8 of 24 (permalink) Old 09-05-2018, 03:22 PM
Thermodyne's Avatar
Auto tuner is for fuel mapping only. The spark retard is hard written to the map. That tuner the MoCo pushes with the canned maps has got to be on of the biggest rips they ever pulled.
Heat is going to make it worse, but it should never ping just cruising. Take it back to the dealer and have them fix it. Or refund your money, riding it like that will kill it real fast. It could in fact have some damage already.
Thermodyne is offline
post #9 of 24 (permalink) Old 09-08-2018, 04:18 PM
turbochrisb's Avatar
What Thermodyne said...do NOT ride it when its pinging/detonating. Take it straight back to the dealer. When itís bad enough to hear itís WAY too much.
rider17 likes this.
turbochrisb is offline
post #10 of 24 (permalink) Old 09-08-2018, 04:20 PM Thread Starter
It has been there since Wednesday.
114 stage 3 freedom1974 Engine Related 36 08-03-2018 11:53 AM
114" M8 stage III cylinders/pistons etc... mtharston Parts for Sale 0 05-02-2018 08:58 PM
Map for Stage 3 - 114 kit Wmoor004 Map Section 7 03-16-2018 09:34 PM
Stage III upgrade from 107 to 114 available Ohiobellboy Engine Related 26 12-23-2017 09:14 PM
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
