Oil Cooled a problem for long distance touring? - Road Glide Forums
 23Likes
post #1 of 17 (permalink) Old 09-19-2018, 04:55 PM Thread Starter
Popx3's Avatar
I'm wanting to buy a RGS which has the oil cooled engine as opposed to the RGU which is liquid cooled. I will be adding a tourpack and riding 2-up and long distance touring in the summertime. I want the RGS so I can get the Industrial Gray Denim with blacked out motor. I have read that the oil cooled system is not as efficient as the liquid cooled. My question for the forum is, will I have a problem with the RGS running hot while loaded down, driving long and hard in the hot summertime?
Popx3 is offline
post #2 of 17 (permalink) Old 09-19-2018, 05:08 PM
calgaryglide's Avatar
Simple answer; NO!!
Up until the "shower head" motors, touring motors were always only oil/air cooled.
You can do more modifications easily to the oil/air cooled motor and many many many many hundreds of thousands of miles, millions even have been put on those motors without any trouble.
Buy the RGS in the color you want, add the tourpak and any other accessories you want and ride it.
If you are travelling in the south of AZ in the extreme heat in the summer you might consider 20W60 oil but otherwise, pick a good synthetic 20W50 oil after break in and change it religiously along with the primary and trans fluid and ride it
Calgaryglide
Lu, glide69, madmat and 4 others like this.
calgaryglide is offline
post #3 of 17 (permalink) Old 09-19-2018, 07:02 PM Thread Starter
Popx3's Avatar
Calgaryglide.....thank you, sir
Popx3 is offline
post #4 of 17 (permalink) Old 09-19-2018, 08:31 PM
Woodman's Avatar
Originally Posted by calgaryglide View Post
Simple answer; NO!!
Calgaryglide
Yep.
Popx3 likes this.
Woodman is offline
post #5 of 17 (permalink) Old 09-20-2018, 02:23 AM
JacktheBagger's Avatar
Till the water bagger came along they were all air/oil only , will be just fine .. personally I do not want a water bagger ...........
Jacksprat56 and Popx3 like this.
2011 Ultra
JacktheBagger is offline
post #6 of 17 (permalink) Old 09-20-2018, 05:42 AM
twowheeladdict's Avatar
If you think you will be caught in stop and go traffic a lot because you are planning to tour all the major cities in the US, then you can add the cooling fans like the lovejugs to help you out.
I had the '16 RGU and now have the '18 Special and no regrets. The non removable lowers on the Ultra made the ride hotter for me because of lack of air flow. Now I can add the lowers in the winter and take them off for the summer.
twowheeladdict is offline
post #7 of 17 (permalink) Old 09-20-2018, 08:50 AM
skratch's Avatar
the newer bikes also have available a fan for the oil cooler, that helps when stuck in stop n go traffic.
Popx3 and crazy4ink like this.
skratch is offline
post #8 of 17 (permalink) Old 09-20-2018, 09:36 AM
jcarruth's Avatar
I love air/oil cooled bikes.
You have added weight and complexity with a liquid cooled engine on a HD touring. And, you are married to having lowers.
Popx3 likes this.
2017 HD Road Glide Special
jcarruth is offline
post #9 of 17 (permalink) Old 09-20-2018, 11:38 AM
JakeC7R's Avatar
Just bought this for my RGS. Have not tried it yet but I figure if it drops the oil temp it can't hurt engine longevity. I am also hoping (thought probably not likely) that it will reduce the furnace on my leg when I get stuck in traffic, maybe a little bit. So if you are worried about engine heat that is another option for you.
Popx3 and Hammerhandle like this.
JakeC7R is offline
post #10 of 17 (permalink) Old 09-20-2018, 08:27 PM
I don't know about the M-8 engines, but on the Twin Cam Road Glides you can install the Road Glide Ultra oil pan and increase you oil capacity by 1.5 quarts, from 3.5 to 5 quarts.
The extra oil will help the engine run cooler.
Popx3 likes this.
Flying Gorilla is offline
Water cooled vs the air cooled engines. ehc0720 *General Road Glide Discussions/Pictures 2 10-25-2014 08:55 AM
My 2014 HD Touring Impressions & Opinion from a Seasoned Long Distance Rider NORSEMAN General Off-Topic Discussions 24 09-03-2013 10:33 AM
New Long Distance Rider from Maine MotDab New Members Welcome Area 57 08-14-2013 05:49 PM
Going on a long distance ride for the first time. Mrs. Iranaround *General Road Glide Discussions/Pictures 34 07-08-2013 06:51 PM
best long distance seat for big guys ? rob883 Seating: seats, backrests 24 05-08-2013 11:42 PM
