M8 Diagnostic Steps for Sumping - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 09-26-2018, 02:54 PM Thread Starter
wevsspot's Avatar
Reading through the latest revision of the Service Bulletin on sumping (M1450 dated 11/15/2017) the MOCO outlines a test/inspection procedure to determine if the M8 motor is sumping. It requires that the bike be ran until engine oil is at operating temperature, then with the bike in the upright position, remove the crankshaft position sensor within one minute, then measure the amount of engine oil that comes out of the port.
On the M8 the CKP location has moved towards the front underside of the case (on the 103 TCs it was near the oil filter). I was curious whether anyone here has done that test as a preventative inspection, and if so how complicated a job is it? Anything to be cautious about?
I don't have any reason to suspect that my 2018 is sumping (or has ever sumped before) but I'd be interested in performing this test during my 5,000mi self service just for poops and giggles
My bike is a RGS with the 107. SE high flow, Rhinehart slimline duals and 4" classic mufflers, PV stage 1 flash from the dealer.
geo8866 likes this.
wevsspot is offline
post #2 of 14 (permalink) Old 09-26-2018, 09:37 PM
You shouldn’t have the sumping issue because your 18 should have the superseded oil pump. Unbolting the CKP isn’t hard and only involves a 3/16” Allen.
wevsspot likes this.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 14 (permalink) Old 09-27-2018, 07:43 AM
Originally Posted by crazy4ink View Post
You shouldn’t have the dumping issue because your 18 should have the superseded oil pump. Unbolting the CKP isn’t hard and only involves a 3/16” Allen.
18s still have sumping. Sadly there are now a couple 19 CVOs that have sumped I have read.
Even though I'm a sumping candidate ('17, stage III, original oil pump) all is well after 10K miles.
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is offline
post #4 of 14 (permalink) Old 10-02-2018, 10:31 AM Thread Starter
wevsspot's Avatar
Thanks for the reply. I have an assembly date of May/2018 on my bike and while it may have one of the newer designed oil pumps, it still doesn't have the revised pump cover (at least not according to all of the information I've read) as the new pump cover only took effect on 2019 bikes, and even then there are still a few reports of continued sumping on 2019 bikes.
I looked for the CKP on my 2018 but it appears that they have moved it. On my 2015 the CKP was right near the oil filter. Any idea where it's at on the M8? A photo would be fantastic if it's not too much trouble. Thank you.
wevsspot is offline
post #5 of 14 (permalink) Old 10-02-2018, 11:18 AM
CPS is front and center of engine. Look right behind plastic cover on bottom. 1 allen head keeps it secure.
msquad is offline
post #6 of 14 (permalink) Old 10-02-2018, 12:05 PM Thread Starter
wevsspot's Avatar
Got it thanks.
That's probably why I couldn't find it (and I don't have my 2018 service manual yet............ I know I know).
It's hidden behind the plastic oil cooler cover, and that explains the whole thing.
wevsspot is offline
post #7 of 14 (permalink) Old 10-02-2018, 12:52 PM
smitty901's Avatar
Yes , I did do the test couple weeks ago. It is easy to do. about 2 oz came out and that took a good twenty minutes to drip out Mine is an early build 2017. 107
Just look under the bike you will see it.
smitty901 is online now
post #8 of 14 (permalink) Old 10-02-2018, 01:44 PM Thread Starter
wevsspot's Avatar
Thanks Smitty. I'll do the test before I start my 5K service.
wevsspot is offline
post #9 of 14 (permalink) Old 10-02-2018, 02:33 PM
So, is there an acceptable amount of engine oil that is allowed to drain and an unacceptable amount as well?
RoadglideinMO is offline
post #10 of 14 (permalink) Old 10-02-2018, 02:47 PM Thread Starter
wevsspot's Avatar
Originally Posted by RoadglideinMO View Post
So, is there an acceptable about of engine oil that is allowed to drain and an unacceptable amount as well?
According to Service Bulletin M1450 that's affirmative.
Following the warm up, test and inspection procedure outlined in the SB.
Up to 6oz is acceptable (although in earlier revisions of the SBs the maximum was 3oz)
Greater than 6oz indicates a possible sumping condition (although in earlier revisions of the SB it was greater than 3oz)
Apparently the mother ship is moving the bar.......................
RoadglideinMO likes this.
wevsspot is offline
Easy Steps To Becoming A Touring Motorcyclist Motorcycle.com *General Road Glide Discussions/Pictures 23 06-08-2016 10:43 AM
Sumping issue Uncleford Engine Related 11 08-13-2014 05:37 AM
Shovelhead sumping AzHogRider Engine Related 10 07-10-2014 07:59 PM
Next steps... Nonpoint Engine Related 5 07-02-2012 05:34 AM
