engine/battery lights on - Road Glide Forums
 13Likes
post #1 of 12 (permalink) Old 10-06-2018, 04:01 PM Thread Starter
Headed for 3 day trip. Started out with battery & engine lights coming on. After 38 miles the volt gauge started to drop from 14 to 8 (not good). Pulled over, checked cables and all tight. Bike would not restart. AAA called (a horror & 3 hour wait). Out come: 4 yr old battery replaced along with a voltage regulator and $450.78 at dealer. Fixed the next day in about 1 hour. Met the guys a day late, good time and bike ran perfect.
Battery was always on tender but was starting to slow start and I did have same lights on once before put went out after aprrox. an hour or two ride.
2012 Road Glide Ultra
antant is offline
post #2 of 12 (permalink) Old 10-06-2018, 05:15 PM
i was 2 hours from home 3 weeks ago. we stopped for lunch. went to leave and battery was dead. made the 3 mile walk to the closest autozone and bought the only battery they had which was 128.00 walked back and installed it and off we went. it happens.
i ride the bike everyday to work ,minus rain days. never had an issue with it, but it was 4 1/2 years old.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #3 of 12 (permalink) Old 10-07-2018, 09:00 AM Thread Starter
I also probably could have needed just a battery also. They did push the regulator on me since I was going on the trip. Help pay for their overhead!
antant is offline
post #4 of 12 (permalink) Old 10-07-2018, 10:05 AM
Stoic Joker's Avatar
Damn I miss the slow semi-predictable death of the old lead acid batteries ... Always seemed to give plenty of warning back in the day.
That and bump starting, man that was always handy in a pinch. I don't even know if it's possible with these new EFI bikes...I suspect not.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #5 of 12 (permalink) Old 10-07-2018, 03:07 PM Thread Starter
With electronic ignition and a dead battery I do not believe you can bump start a bike.
antant is offline
post #6 of 12 (permalink) Old 10-07-2018, 07:23 PM
1st Sgt's Avatar
My Voltage Regulator went out up in northern Arizona in the middle of flipp'in nowhere. Feel your pain but at least your back on the road pretty quick.
1st Sgt is offline
post #7 of 12 (permalink) Old 10-07-2018, 10:08 PM
Rusty's Avatar
Man I got to the point I carry something similar to this.. Very handy in a pinch. For under $75 it is cheap insurance.. https://www.amazon.com/GOOLOO-18000m...s+for+vehicles
https://www.youtube.com/watch?v=87Zgq7wsi24
RGKen likes this.
Rusty is offline
post #8 of 12 (permalink) Old 10-08-2018, 07:48 AM
RGKen's Avatar
I know that jump starting a bike from a car can be really bad so I would normally be very skeptical about using a jump starter designed for a car battery on my bike. Looks like this one says it works with motorbikes, snowmobiles, and ATV's etc... so this could be a good one have. Thanks for posting this!
Rusty likes this.
2018 FLTRXS
RGKen is offline
post #9 of 12 (permalink) Old 10-08-2018, 09:17 AM
wevsspot's Avatar
Originally Posted by RGKen View Post
I know that jump starting a bike from a car can be really bad so I would normally be very skeptical......
I've read a lot of the same horror stories, but on the flip side we've had to jump start two 2015s that had us stranded out on the road, with nothing but a helpful motorist to lend a hand both times. I guess we were lucky in that we didn't tear anything up in those situations. I go directly to starter with the positive lead of the jumper cable and then ground the negative lead on the frame. Haven't ever tried it going directly to the battery.
RGKen, Rusty and ALMOONEY like this.
wevsspot is offline
post #10 of 12 (permalink) Old 10-08-2018, 09:33 AM
RGKen's Avatar
Sometimes you have to do what you have to do and as long as you take the cables off right away it may keep from any damage happening. I've actually been successful myself but have had 2 buddies that weren't so maybe it's luck sometimes.
wevsspot likes this.
2018 FLTRXS
RGKen is offline
Check Engine & Battery Lights?? George W Troubleshooting for Road Glides 3 08-11-2016 01:35 AM
Engine and battery light Onthehunt49 Troubleshooting for Road Glides 31 03-08-2016 10:56 PM
LED - Accent lights battery drain Cakeman1 Lighting 6 03-16-2015 11:17 AM
check engine and battery light drmudd Troubleshooting for Road Glides 11 04-20-2013 01:08 PM
New Bike - Engine & Battery Light pscan5150 Troubleshooting for Road Glides 15 06-08-2012 05:02 PM
