What Lifters? - Page 3 - Road Glide Forums
 5Likes
post #21 of 23 (permalink) Old 10-11-2018, 12:43 PM
I have a 2010 FLTRX 24,000 miles at the time did the whole motor lifters pushrods Fueling related fueling 500 miles on the new build was making a noise it dropped a pushrod we opened up the cases to look around and I thought I may as well do the oil pump in cam chest again Fueling best upgrade I ever did it actually improved the throttle response 35 psi at ideal 60 psi under power regardless how hot this summer temperature oil temp never over 235 Amsoil in all three holes ride safe bored the cylinders for 200.00 107ci
vincem1
scarlet red 2010 RG
vincem1 is offline
post #22 of 23 (permalink) Old 03-23-2019, 08:43 AM
Comp Cams 850-1 SBC Roller Lifters......Are these lifters better than the stock ones and are they has good has S&S premium lifters ??
Can i use my stock pushrods with comp cams 850 lifters?
Z-809 is offline
post #23 of 23 (permalink) Old 03-24-2019, 09:27 PM
Desertwndrr's Avatar
They are significantly better than stock. Comparable to the S&S standards. You can use your stock pushrods.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
Harley B lifters TXcruiser Engine Related 9 05-02-2012 12:21 AM
Gaterman lifters J.I.M.S. Classifieds Archive (3 months old+) 3 04-19-2012 06:34 PM
SE255 cams and lifters kevdon Classifieds Archive (3 months old+) 12 04-15-2012 12:08 PM
Jims PowerGlide II Lifters roadyrich Engine Related 7 01-15-2012 06:26 PM
lifters hardrock Aftermarket Accessories 0 11-29-2011 07:52 PM
