Tools for main drive bearing and race refresh? - Road Glide Forums
post #1 of 1 (permalink) Old 10-25-2018, 02:36 PM Thread Starter
not sure if the engine section was the appropriate section for this question, mods please move if i'm in the wrong neighborhood.
while i have my engine out for a 117" build i figured i'd go ahead and replace the shift shaft seal, S&S inner primary race, new inner primary bearing, new main drive bearing (i have the older one with the plastic cage). looks like most of these areas require specialty tools.
got some quotes from local shops but all of them seemed high so i was seeing what tools i would need to buy to repair myself. figured i could sell the tools after. could anyone confirm these are the right tools i need? read through the manual and think i got them all...
  • main drive gear and bearing tool
  • main drive gear seal installer (small)
  • main drive gear seal installer (large)
  • mainshaft race tool
  • shifter shaft seal installer
  • sprocket locking tool
  • sprocket nut socket
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
Main drive sprocket Clutch1 Engine Related 9 01-14-2017 05:23 PM
Main Gear Drive Bearing failure Hullhorr Engine Related 68 10-15-2015 08:43 AM
Main bearing seal GLYDDN11 Do-IT-Yourself 17 11-14-2014 05:22 PM
Heartland Tools Inner Cam Bearing Installer & Puller for 96, 103, and 110 daryl_db Parts for Sale 2 08-22-2014 09:59 AM
Main gear drive bearing failure 2010 RGC glideriderdave Engine Related 3 02-02-2013 06:08 PM
