2012 CVO limp throttle PLEASE HELP! - Road Glide Forums
 5Likes
  • 2 Post By HellInABucket
  • 2 Post By direwolf
  • 1 Post By ironmark
post #1 of 9 (permalink) Old 10-26-2018, 09:29 AM Thread Starter
Lord Vader's Avatar
My friends 12 CVO has a strange problem. When it gets hot the throttle goes limp. He replaced the TBW and the connector going to the throttle body. He also swapped out ECM's to see if that was the problem. Anybody know what could cause this? It will be running fine and then all of a sudden it slows down and won't go past idle. Charging system seems fine. Stock stage 1 110" motor.
JOIN THE DARK SIDE
Lord Vader is offline
post #2 of 9 (permalink) Old 10-26-2018, 10:39 AM
HellInABucket's Avatar
From the symptoms you describe, it must be throwing codes, I'd try to retrieve those instead of swinging wildly like he is now.
ironmark and crazy4ink like this.
HellInABucket is offline
post #3 of 9 (permalink) Old 10-26-2018, 11:00 AM
direwolf's Avatar
I had this problem on my 2009 FLTRSE3,
If you are referring to the TCA (throttle control actuator) behind the air cleaner (at 9:00 position), ask your dealer for Technical Service Bulletin TT418A. It's not the wires, it is the Pins in the plug wearing from vibration and not making contact.
https://www.roadglide.org/28-trouble...d.html?t=15727
RGKen and duglauraflht like this.
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #4 of 9 (permalink) Old 10-26-2018, 11:01 AM
Yes you should check for DTC's and see if there is anything there. Just a wild guess but maybe the Engine temp Sensor could be the problem.
Big_gary likes this.
post #5 of 9 (permalink) Old 10-28-2018, 09:06 AM
Trendkill's Avatar
If it's purely heat related, this would be my first guess as well.
2018 Road Glide Special in Bonneville Salt Pearl - Stage II Power, SVT Boneshaker exhaust
Trendkill is offline
post #6 of 9 (permalink) Old 10-28-2018, 10:44 AM
RGKen's Avatar
I had the same issue on my 2010 and this^^^^^ is what it was. It is a very common problem and a fairly simple fix.
2018 FLTRXS
RGKen is offline
post #7 of 9 (permalink) Old 10-28-2018, 11:10 AM
Desertwndrr's Avatar
Friend of mine just had a very similar issue. Turned out to be an engine temp sensor. Easy fix.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #8 of 9 (permalink) Old 10-28-2018, 06:54 PM
As has already been said; first thing to do is check for DTCs. More than likely the engine temp sensor is bad. On the left side of the bike, front cylinder, behind the horn, you should see a 2 wire connector. That's the temp sensor. The sensor threads into a blind hole so no fluids or anything will come out when you remove it.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #9 of 9 (permalink) Old 08-15-2019, 09:31 AM
Rob-B's Avatar
I had bad TCA connector pins causing Limp Home mode and code for Throttle Demand at inopportune times.
First of all - it's generally an intermittent problem.
Metallic expansion as temperature goes up can affect bad connectors.
Cycling the ignition Switch OFF / ON three times may reset the limp until next time the pin(s) lose contact.
Mine was fine - hot, hit a cooling mist of rain and it would limp.
Nick, my mechanic replaced the pins per the Harley Davidson TSB. Fixed.
Rob-B is offline
Limp Mode hd4cruzin Troubleshooting for Road Glides 11 10-01-2015 09:12 AM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
Limp Mode Solution ODA CDR (RET) *General Road Glide Discussions/Pictures 4 07-20-2012 06:22 AM
limp mode teepee Troubleshooting for Road Glides 9 07-28-2011 09:38 AM
Hester Went intoi Limp Home Mode - Insight? Shrug *General Road Glide Discussions/Pictures 21 06-15-2011 07:21 PM
