1992 Ultra oil/psi and Vol/gauge@9 - Road Glide Forums
post #1 of 4 (permalink) Old 11-15-2018, 09:49 PM Thread Starter
92Dinoglide's Avatar
1992 Ultra oil/psi and Vol/[email protected]
Ridding at operating temperate (70mph-2700rpm) my oil pressure gauge read 9psi+- and my voltage gauge read 9+-v...pulled over everything sounded fine/tight. Rode the 10 miles into town and had to stop at two traffic lights looked down and meters were both back to normal 20psi 14v..??? Sounds like a wiring prob but everything is in place? This is a ‘92 Ultra...not a computer bike
92Dinoglide is offline
post #2 of 4 (permalink) Old 11-15-2018, 09:59 PM
It sounds like a wiring issue to me. More than likely in the fairing. There is a harness that feeds your 4 small gauges. Depending on how the harness it routed around the fairing support brackets, a wire could be rubbed through by the metal. If you know you have oil and there are no odd sounds, and you have checked your battery, at the terminals, with a multimeter and your bike is charging, I would then check the wires in the fairing.
2018 FLTRXS Wicked Red
Harley Master Tech
crazy4ink is offline
post #3 of 4 (permalink) Old 11-16-2018, 06:49 AM
Stoic Joker's Avatar
Not a lot of metal in a 92 fairing, but I'm with Crazy on the location. Everything in the fairing is dependent on a ground wire that is attached to the two bolt fairing mount behind the headlights that is easy to break if stuff is packed up in that area, and/or snags it a few times..
Years ago I had two coffee cups sitting on top of a pup tent that was stuffed into the fairing of my 82 (during a run) that drove me nutz for months, because (I'd forgotten about the tent...) they were tinking together going down the road.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #4 of 4 (permalink) Old 11-16-2018, 03:39 PM Thread Starter
Great info about the ground wire behind the lights, it will be taken down this winter! Thank you both
$5500obo - 1992 Ultra Classic Tour Glide vansmetal88 Bikes for Sale 16 10-11-2018 07:08 PM
Genuine Harley PSI gauge and tread depth tool ppalmerjr Parts for Sale 1 01-08-2016 08:28 PM
Blue and white RGC stock gauges and PSI gauge RichieRich Parts for Sale 23 03-20-2015 10:52 PM
1992 TourGlide Ultra Classic Production Numbers? asheborogn *General Road Glide Discussions/Pictures 14 07-22-2012 03:51 PM
use of a oil pressure gauge for air psi??? bigeyed76 Equipment-RG 9 03-11-2012 10:31 PM
