107" m8 to 117/124" 2018 fltrx - Road Glide Forums
 3Likes
  • 3 Post By Smarty
post #1 of 8 (permalink) Old 12-08-2018, 10:30 AM
mucyou
Guest
Posts: n/a
Know my stock barrles can be bored to the 117" , also that 124" barrles are avaible that do not need cases bored/split . Will the 107's bored to 117" have thinner wall than the 124" barrels ? As have heard tell the 124" 1's will hold up longer . thanx for any info from those in the know or that have done this .
post #2 of 8 (permalink) Old 12-08-2018, 01:16 PM
A quick call or email to Fuel Moto would be in order- they can answer any and all related questions about the variations between the two kits.
RoadglideinMO is offline
post #3 of 8 (permalink) Old 12-08-2018, 02:54 PM
Smarty's Avatar
Originally Posted by mucyou View Post
Know my stock barrles can be bored to the 117" , also that 124" barrles are avaible that do not need cases bored/split . Will the 117's bored to 117" have thinner wall than the 124" barrels ? As have heard tell the 124" 1's will hold up longer . thanx for any info from those in the know or that have done this .
Send a set of stock cylinders to Tman Performance and have him do the 124 sleeves. He removes the sleeve from the 107, bores the casting to except the new much thicker sleeve and allows it to hang into the cases further so the pistons never come out of the sleeve at the bottom. I love that someone is finally doing something about the 124" builds Twin cam or M8. Piston rock has always been problematic in this type of build because of the shortness of the overall piston and the pin location on the piston. I believe this setup will prove to be very reliable and his custom made pistons have 3mm oil rings. A must in my opinion.
RGKen, MyGlide and mucyou like this.
2016 RGS Black Quartz
Smarty is offline
post #4 of 8 (permalink) Old 12-08-2018, 05:51 PM
mucyou
Guest
Posts: n/a
thanks for pointing me in the correct direction smarty
post #5 of 8 (permalink) Old 12-08-2018, 06:15 PM
MyGlide's Avatar
Is this something new that may not be on his site yet? I just looked at his site after reading your post and it only showed a cylinder/piston kit that would change the 107 to 120. Below is what is written on his site.
"This kit comes in two versions – 120-cubic inch and 124 cubic inch kit. The final motor size is determined by the existing stroke on your factory bike.
This 124ci kit is used for all 2017/2018. CVOs come from the factory with the Screaming Eagle™ cylinders installed. Your stock cylinders can be supplied for boring to the 4.180 bore which will increase the cubic inch to 124″.
2018 KTM Super Duke R
MyGlide is offline
post #6 of 8 (permalink) Old 12-08-2018, 07:37 PM
Swoop76's Avatar
Correct the site is not updated yet but check out his YouTube you can to to 124 sending in 107 stock cylinders to have bored and sleeved which I’ll be doing soon thanks to @Smarty for doing extensive research.
https://youtu.be/gOoDmViH4WQ
Swoop76 is offline
post #7 of 8 (permalink) Old 12-08-2018, 10:23 PM
MyGlide's Avatar
Thanks Swoop, just watched the video. Looks good, I'll be calling them to check on availability and pricing.
MyGlide is offline
post #8 of 8 (permalink) Old 12-09-2018, 08:24 AM
Clutched's Avatar
I see you live in Rochester why not get a hold of Hillside Cycle in Munnsville,They are great an close to you or get a hold of Ray at Hulten Speed Sports in Oppenhiem he is close to me has awesome setups,And a very good Dyno that's where I go only 25 min from the house,He did my new RGS runs good.Either one is Very good an not far from you They both have web sites,Check out Hulten Speed Sports though,He dose a lot of Harleys in upstate NY an has some great setups.
2018 Wicked Red Road Glide Special 14 in.Yaffe Monkey Bars,Rinehart Slimline Duals,Power Vision Dynoed,Arlen Ness Big Sucker,Mustang seat,!4 in. Klock Werks Sport Tour Windshield.Cerwin Vega B52,Infinity Kappas.
Clutched is offline
2018 CVO M8 117, Wood 22X cam, Jackpot 2/1/2, S&S mufflers fuelmoto Fuel Moto 6 01-12-2018 10:02 AM
Fuel Moto M8 124" big bore kit 114 & 117 engines fuelmoto Fuel Moto 0 01-11-2018 12:09 PM
2018 CVO M8 117, Wood 22X cam, Jackpot 2/1/2, S&S mufflers fuelmoto Dyno Results 4 12-15-2017 03:23 PM
117" or 124"? abone Engine Related 16 09-08-2015 07:50 AM
117" build or 124" S&S glide69 Engine Related 13 07-02-2015 06:00 PM
