over size pistons - Road Glide Forums
post #1 of 6 (permalink) Old 12-15-2018, 08:48 AM Thread Starter
Question over size pistons
I have a 15 rgs, can i bore my cylinders to put in bigger pistons? Will that increase hp. & torque? Is it better & cheaper to buy the big bore kit? Thanks.
nanook is offline
post #2 of 6 (permalink) Old 12-16-2018, 08:01 PM
Do you have someone local that can bore the cylinders properly and get you the correct size pistons? If so, it is cheaper to go that way
phillyfan1 is online now
post #3 of 6 (permalink) Old 12-16-2018, 08:09 PM
JacktheBagger's Avatar
Yes , Yes and Yes .. But just boring will not attain much in the way of HP and torque ..You will gain only a few cubes at best .. You would do better to get a kit ...
2011 Ultra
JacktheBagger is online now
post #4 of 6 (permalink) Old 12-17-2018, 08:31 AM Thread Starter
Question
I had the stage IV kit installed when i bought the bike. I was thinking if i went .20 or .30 over on the pistons would help?? I have a local machinist to do the work.
nanook is offline
post #5 of 6 (permalink) Old 12-17-2018, 10:35 AM
kouack's Avatar
Better look somewhere else if you are after more power, like have it tune properly if your stage iv was done by a harley dealer with only a flash tune. What exhaust you have? Going bigger without all the supportive accessories will not help. Maybe look at 107 or maybe a 110 drop in kit? Talk with shops, like fuelmoto, hillsides just to name a couple they will steer you in the right direction.
Envoyé de mon iPad en utilisant Tapatalk
kouack is offline
post #6 of 6 (permalink) Old 12-17-2018, 01:15 PM
Thermodyne's Avatar
You can punch them .005 or .010.
But that's just about reusing jugs, not gaining displacement. 103.19 is what the motor is oem. At 10 over you get a whopping 103.72.
If you want more inches, ya need to step up to 4 inch jugs. You can drop them in with steel liners, or cut the cases and use oem 110 iron lined jugs.
Thermodyne is offline
Cold Start Issue - Won't turn over below 40 but starts fine when over 40 KRav7 *General Road Glide Discussions/Pictures 11 12-13-2016 11:31 PM
It aint over till it's over JacktheBagger General Off-Topic Discussions 3 09-24-2015 12:26 PM
Just found some heads, what cam and pistons? 19Cobra96 Engine Related 0 11-05-2011 12:16 AM
2011 RG Custom with headwork, cams, pipes, pistons etc AZroadrunner Dyno Results 9 04-23-2011 04:27 PM
