2019 Updated Oil Pump Cover - Road Glide Forums
 14Likes
post #1 of 14 (permalink) Old 12-16-2018, 01:50 PM Thread Starter
Desertwndrr's Avatar
I can confirm that not all 2019 models received the new pump cover designed to limit or eliminate the sumping issues. My bike is a RGS with the 114. Build date 8/18. Ive had no issues so far and only pulled the cover to swap cams, lifters, and change out the inner cam bearing to a full compliment B168 bearing.
On a really positive note, my crank runout measured .001. Pretty excited about that.
JayKS, madmat, Mike U and 3 others like this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #2 of 14 (permalink) Old 12-16-2018, 04:13 PM
madmat's Avatar
I had read some early release 19's don't have the the new cam plate yet.
Great news on the run out!
What cam are you putting in?
18 RGS Bonneville Salt Pearl
madmat is offline
post #3 of 14 (permalink) Old 12-16-2018, 04:19 PM Thread Starter
TTS100 Torque Cam. Not looking to get too crazy with Cams and motorwork. Just a little extra oomph.
post #4 of 14 (permalink) Old 12-16-2018, 05:26 PM
madmat's Avatar
Excellent, looking forward to feedback!
madmat is offline
post #5 of 14 (permalink) Old 12-16-2018, 08:53 PM
I'm thinking of the tts 100 would like to know what you think of it. What tuner are you using
Bob1836 is offline
post #6 of 14 (permalink) Old 12-16-2018, 10:10 PM Thread Starter
Ive used TTS tuners in every HD Ive owned. Will post back up after the Cams are installed. I had to order parts based on what I found today.
post #7 of 14 (permalink) Old 12-22-2018, 07:06 PM Thread Starter
The TTS100 cams are beautiful in the 114 motor. Just got done with a 350 mile shakedown and VTune run. Hard to describe how well the bike ran. Torque everywhere. In 6th gear Id slow down to 40 mph and the bike would pull smoothly without bucking or shuddering. The ride consisted or rolling in and out of the throttle with little need to shift, even when pulling grades or passing.
I also got a photo of the two pump covers before I buttoned the bike all back up.
post #8 of 14 (permalink) Old 12-23-2018, 09:49 AM
glidedawg's Avatar
Is there a known production date as to when the 19's were fitted with the new pump parts?
Industrial gray denim 2019 fltrxs
Bassani r/r 2-1
RIDE ON
glidedawg is offline
post #9 of 14 (permalink) Old 12-23-2018, 02:04 PM
Little Wing's Avatar
Originally Posted by Desertwndrr View Post
The TTS100 cams are beautiful in the 114” motor. Just got done with a 350 mile shakedown and VTune run. Hard to describe how well the bike ran. Torque everywhere. In 6th gear I’d slow down to 40 mph and the bike would pull smoothly without bucking or shuddering. The ride consisted or rolling in and out of the throttle with little need to shift, even when pulling grades or passing.
thanks for sharing!
looks to be a lot better seal.
if the pump wasn't making a good seal it would cause cavitation, which would result in sumping, right?
if that's right, how could it have ever made it to the production stage???
Little Wing is offline
post #10 of 14 (permalink) Old 12-23-2018, 04:46 PM Thread Starter
October of 2019
M8 oil pump cover crazy4ink Engine Related 2 10-17-2018 12:10 PM
Fueling Oil Pump for 07 and newer mikespeedshop Engine Related 10 06-25-2012 06:09 AM
feuling cam plate and oil pump 07-11 T/C digga25 Classifieds Archive (3 months old+) 0 05-11-2012 09:01 PM
feuling race series oil pump digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:31 AM
stock oil pump 09 cvo 110 digga25 Classifieds Archive (3 months old+) 0 03-30-2012 06:13 AM
