Cams 120r - Road Glide Forums
post #1 of 5 (permalink) Old 12-27-2018, 11:45 AM Thread Starter
Cams 120r
What cams is everybody using to get a little more power Out of the 120r motor ?
Chicagoguy is offline
post #2 of 5 (permalink) Old 12-27-2018, 11:47 AM
Best bet is to go to the tech forum and look for dyno sheets with your setup. See if the power is coming on where you want it too. Then a quality tune done by a quality tuner
phillyfan1 is offline
post #3 of 5 (permalink) Old 12-27-2018, 12:46 PM Thread Starter
Thanks
post #4 of 5 (permalink) Old 12-27-2018, 01:10 PM
SteadyEddie's Avatar
Not sure of this helps but on my old built to shit 2015 TC that started life as a 103 and had the Revolution Performance 117Kit with CNC Heads, 58MM TB and a shit ton more....I ran these and was not disappointed
https://www.fuelmotousa.com/i-208596...camshafts.html
SteadyEddie is offline
post #5 of 5 (permalink) Old 12-27-2018, 02:37 PM Thread Starter
A lot of people are saying to go with woods cams i love the power now just comes on late in the Power band and they say 999 or the 408 to go with
cams,cams,cams dozer23 Engine Related 2 03-03-2017 08:18 AM
Screamin Eagle 120r stock cams- 266 panhead Parts for Sale 3 03-31-2014 08:58 AM
120R T-man 662-2 Cams robertg Dyno Results 22 06-04-2013 08:37 AM
Pcv map for 120R bigtwin ECM/Fuel Management systems 0 11-12-2010 10:49 PM
SE 120r NakedSnowman Engine Related 22 10-13-2010 12:43 PM
