2015 RGS cam chain tensioner shoe inspection - advice? - Road Glide Forums
 3Likes
post #1 of 28 (permalink) Old 01-08-2019, 09:24 PM Thread Starter
Hey All, so I am at roughly 50k on my 2015 RGS so as preventative maintenance I thought I’d take a peek at my chain case components as well as my cam chain tensioner shoes. I’m also due for a fork rebuild, next on the docket.
Now, I know the new hydraulic tensioner design is less susceptible to failure in comparison to the old spring style, but it’s not that much work to at least have a look at the outer shoe to get a gauge of the amount of wear, so I’ve taken off the camchest cover & had a look.
Overall, the outer shoe looks good, and by deduction, I assume the inner is in similar shape (maybe .015” of wear) so I was planning on just buttoning it back up as-is; however, I was considering this as a possible opportunity for a cam upgrade. I already have a stage 1 with a power vision, so it’s a natural progression. With that being said, I was really thinking of holding off another year, just because I hadn’t planned on spending the dough quite yet.
Here’s the conundrum... With all of that being said, I started calling around to a few shops just to get some pricing ideas, and the consensus from the shops is that not only are my lifters suspect & could be subject to failure, but also that the inner cam bearings could also be a possible “ticking time bomb” at my mileage. Part of me thinks that while there may be some kernel of truth behind the shops comments, they are also in the business of selling things, so of course there’s an opportunity for them to sell some goods. By no means am I saying these places are merely trying to sell me on scare tactics, I’m just trying to be mindful of that aspect and keep it in perspective.
So I guess the question is, what’s the general consensus here about these specific internal components that are being specifically called to the mat and could hold a real potential for failure, or would y’all just button it up & ride it, taking the chance that nothing will go wrong? I know it’s a bit subjective since there are a lot of variables that come into play.
For reference, I am pretty darn religious about changing oil & filter every 5k, and have used either Castrol 20-50 vtwin syn or schaeffer 20-50 vtwin syn oil after the 1k break-in oil was changed. I don’t do burnouts or wheelies, but do twist the wick and have fun when the mood strikes. Ride to & from work everyday (about 50 mi round trip - mostly highway) with some long road trips mixed in every year.
It’s tough because, would I like cams? Absolutely. Do I need them? Not really - but these comments coming from some respected shops have me a bit concerned about the chances I would be taking, according to them, by running it as-is for another season, so approx. 15k miles.
What say you?
Shadowbennie is offline
post #2 of 28 (permalink) Old 01-09-2019, 12:00 AM
Desertwndrr's Avatar
With the newer motors I replace the lifters AND the inner cam bearings within the first 5000 miles. The hydraulic chain tensioner shoes havenít been replaced in any bikes yet.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #3 of 28 (permalink) Old 01-09-2019, 05:17 AM
Ohiobellboy's Avatar
What do you mean by "newer motors" Troy? Any TC or M8? I see he has a TC. I never read much about lifter issues on a stock 103 TC if that is what he has as he didn't mention it being a CVO with the 110 (in which the stock lifters would have been replaced by now)
A.K.A OBB
Ohiobellboy is offline
post #4 of 28 (permalink) Old 01-09-2019, 07:44 AM Thread Starter
Yes, stock 103HO with stage 1 a/c, Dragula 2 pipes & powervision. The lifters for the twin cam engines don't seem to be as prominently discussed on forums even though I have read a few threads on them regarding questionable reliability, but the stock inner cam bearing has been a topic of concern & discussion for some time. The one shop that mentioned this as a primary concern basically said that the TC motors, especially '09 and up, are using a bearing akin to what was used in the EVO motors, which had a fairly significant failure rate from what I understand.
post #5 of 28 (permalink) Old 01-09-2019, 07:58 AM
MisterEd's Avatar
Originally Posted by Shadowbennie View Post
>>>I was considering this as a possible opportunity for a cam upgrade. I already have a stage 1 with a power vision, so itís a natural progression. With that being said, I was really thinking of holding off another year, just because I hadnít planned on spending the dough quite yet.
Hereís the conundrum... With all of that being said, I started calling around to a few shops just to get some pricing ideas, and the consensus from the shops is that not only are my lifters suspect & could be subject to failure, but also that the inner cam bearings could also be a possible ďticking time bombĒ at my mileage. Part of me thinks that while there may be some kernel of truth behind the shops comments, they are also in the business of selling things, so of course thereís an opportunity for them to sell some goods. By no means am I saying these places are merely trying to sell me on scare tactics, Iím just trying to be mindful of that aspect and keep it in perspective.
So I guess the question is, whatís the general consensus here about these specific internal components that are being specifically called to the mat and could hold a real potential for failure, or would yíall just button it up & ride it, taking the chance that nothing will go wrong? I know itís a bit subjective since there are a lot of variables that come into play.
Itís tough because, would I like cams? Absolutely. Do I need them? Not really - but these comments coming from some respected shops have me a bit concerned about the chances I would be taking, according to them, by running it as-is for another season, so approx. 15k miles.
What say you?
Just do the cam upgrade. All cam bearings, lifters, all chain tensioners (zipper or Feuling), adjustable push rods and also add the LMR oil pressure spring. This will add about $300 to the bill for parts and the labor, well you're already paying for that with the cam install.
RGKen and Little Wing like this.
MisterEd is offline
post #6 of 28 (permalink) Old 01-09-2019, 08:10 AM
I meant the newer TC with hydraulic Tensioners. The lifters are junk. After model year 09 Harley began using a new vendor and the lifters just donít hold up. Every bike Iíve pulled apart has shown frosted and flaking plating on the rollers.
post #7 of 28 (permalink) Old 01-09-2019, 09:58 AM Thread Starter
I'm leaning that direction - getting the feedback I did regarding the inner cam bearing from one shop & a friend of mine who has done an engine build is pushing me that direction. However, what's the rub on replacing the hydraulic tensioner assemblies? - are those really that crappy as well? I planned on new shoes, but hadn't intended on getting the hydraulic portion.
I would do the install myself as my buddy has the cam bearing tool, and he has experience installing his own cams as well (he's also a drag car builder that races at B.I.R. so he knows a bit about engines....)
post #8 of 28 (permalink) Old 01-09-2019, 04:02 PM
MisterEd's Avatar
However, what's the rub on replacing the hydraulic tensioner assemblies? - are those really that crappy as well? I planned on new shoes, but hadn't intended on getting the hydraulic portion)
IMO...HD tolerances are not that great. The quality aftermarket is better so if Iím in there change it. Also, take a look at the LMR oil pressure spring. When installed correctly it will boost you hot psi about 4, cold about 6.
Just sharing my experience. Good luck.
MisterEd is offline
post #9 of 28 (permalink) Old 01-09-2019, 04:23 PM Thread Starter
Well, I suppose this whole situation is a manifestation, in itself, of your comment regarding HD's sketchy tolerances anyway - the fact that I'm even having to do consider changing cams, lifters, bearings, etc to ensure that my engine doesn't grenade is somewhat comical & also sad - but then again, maybe most HD owners don't put close to 50k on their rides before they trade them off, sell them, or it merely takes 10 years to get there, which by that time, they have already done cams for pure performance reasons anyway......
So, I guess I'll consider the new tensioner hydraulic assy as well - what's your thoughts on the fueling tensioner/hydraulic setup? They're not that much less than the zippers tensioner assemblies I guess, but less $$ is less $$. Fueling's still appear to be a single piston design, and I'm sure are still much better than HD's. Reading about Zipper's design, and although it seems to be an awesome design, is the tensioner pad rocking really an issue, even with bolt-in style cams? Or are they somewhat engineering a design to solve a problem that isn't all that prominent?
Yeah, I thought about the plunger & spring too - but maybe just get the LMR spring if anything. I guess I'll have to see what my cam plate & oil pump look like when I'm in there......
post #10 of 28 (permalink) Old 01-16-2019, 06:36 PM
MisterEd's Avatar
I looked at the Zipper dual piton but chose the single to be safe.
The big thing about the new plunger is seating it in the cam plate. The instructions lay it out. The piston is modified to seal better and not allow leaking around it. It allows higher oil pressure until the pressure over comes the spring and then bypasses.
MisterEd is offline
How To Adjust A Motorcycle Chain Motorcycle.com *General Road Glide Discussions/Pictures 7 06-28-2016 12:02 PM
$850.00 cam chain tensioner replacement. Should I? Hog Indo *General Road Glide Discussions/Pictures 7 06-02-2015 12:21 PM
cam chain tensioner shoe wear Nordic Berserker Engine Related 8 04-20-2015 06:19 AM
FS: Hayden Primary Chain Tensioner JayKS Sold 4 02-11-2015 02:48 PM
Chain tensioner Jerry W. Engine Related 4 06-29-2012 08:09 PM
