Shifter sleeve replacement - Road Glide Forums
post #1 of 4 (permalink) Old 01-09-2019, 06:44 PM Thread Starter
Thermodyne's Avatar
Has anyone replaced a shifter shaft sleeve in a cruise drive yet?
Was adjusting the primary chain on my 11 today and noticed there was some shockproof on the shift lever at the trans. That pawl shaft has been loose in the sleeve pretty much since day one.
Looks like a lot of work for a $2 sleeve.
Thermodyne is offline
post #2 of 4 (permalink) Old 01-10-2019, 01:37 PM
BH#103's Avatar
It's just removing the inner and outer primaries and getting the shift lever out of the way. I never actually replaced one, but I've been close enough to. Like old repair manuals say, simply remove, simply install. Don't use an impact gun on the compensator either. Good luck.
"SLIVER"
BH#103 is offline
post #3 of 4 (permalink) Old 01-10-2019, 02:03 PM Thread Starter
Thermodyne's Avatar
According to the book, I'd be pulling the gear set. After looking around a little, I saw that Jims has a new (ish) tool that lets you drive the bushing out with the pawl in place. That'll take some of the chore out of it.
post #4 of 4 (permalink) Old 01-10-2019, 02:10 PM
BH#103's Avatar
My bad man, I reread the title. I was thinking seal. Sorry for the confusion. Still good luck to you! Please share your work on it, I'm interested.
"SLIVER"
BH#103 is offline
Broken shifter crossbonesglide Do-IT-Yourself 2 07-04-2016 09:17 AM
Forward gear shifter problem canukHD Aftermarket Accessories 9 02-21-2016 07:31 PM
Heal shifter not adjusted correctly Jhl192 Controls & Handlebars 8 10-19-2015 11:15 AM
Performance Machine Shifter, Stock TRibar setup ChromeYellow67 Parts for Sale 1 05-12-2015 06:33 AM
Pingle shifter for newer 6 speed Harleys FLTR2008Trike Classifieds Archive (3 months old+) 1 01-20-2012 09:52 PM
