Single Ting from Primary with Throttle Twist - Road Glide Forums
post #1 of 3 (permalink) Old 01-10-2019, 10:04 AM Thread Starter
sethc1020's Avatar
Hello all! New to the site and hopefully someone can help me out. I have a 2012 RGU with a little over 13K on it, just bought it last summer. I've noticed when the engine warms up I will hear a single metallic "ting" from inside the primary if I get on the throttle aggressively. It will do the same thing sitting in neutral or in gear riding down the road. Im thinking it may be the chain taping the inside of the case but not sure. If so could that be a tensioner issue possibly? Other than that it runs and rides great but that ting bothers me.
Thanks in advance!
sethc1020 is offline
post #2 of 3 (permalink) Old 01-10-2019, 10:44 AM
Thanks in advance!
You really need to pull the outer cover and have a look and go from there. It could be a few things but probably is the compensator.
post #3 of 3 (permalink) Old 01-10-2019, 11:53 AM Thread Starter
sethc1020's Avatar
Thats what I was planing on doing to see if the chain has been hitting the cover. I don't think its the compensator because its just a single Ting with a good twist of the throttle. No problems at start up or when shutting off the bike, thats what makes me think it could be a tensioner.
Will FP3 fix choppy throttle and sluggish response when passing MBigButt ECM/Fuel Management systems 9 07-21-2016 04:05 AM
How To Adjust Throttle Free Play And Why Motorcycle.com *General Road Glide Discussions/Pictures 1 03-14-2016 11:25 AM
Inner Primary Woes DED HD Troubleshooting for Road Glides 3 10-14-2015 06:57 PM
new twist grip efi throttle installed jaysandy Troubleshooting for Road Glides 16 04-28-2014 05:29 PM
New S&S Throttle Bodys Hillsidecycle.com Engine Related 10 08-28-2012 06:19 AM
