Cam install time - Road Glide Forums
 13Likes
post #1 of 15 (permalink) Old 01-12-2019, 03:36 PM Thread Starter
Galooch's Avatar
Cam install time
Decided today was a good day to work on the bike as it's 20°outside.
madmat likes this.
Galooch is offline
post #2 of 15 (permalink) Old 01-12-2019, 03:39 PM Thread Starter
Galooch's Avatar
Was going well pretty well until I got to the lifter cuffs. One of the bolts broke off. Too much locktite, I'm guessing. It was just at the dealer for a set of lifters in October......
Galooch is offline
post #3 of 15 (permalink) Old 01-12-2019, 03:41 PM Thread Starter
Galooch's Avatar
More pics
Galooch is offline
post #4 of 15 (permalink) Old 01-13-2019, 11:14 AM
hd4cruzin's Avatar
Which Woods cam is that? What tuner are you going to use. Interested in the results.
That should wake up your bike.
2012 FLTRX BBP
hd4cruzin is offline
post #5 of 15 (permalink) Old 01-13-2019, 12:27 PM
Little Wing's Avatar
ouch.
do you have a plan for getting it out?
thanks for posting up. love to see the heart of a bike exposed like this!
engine porn lol
madmat likes this.
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #6 of 15 (permalink) Old 01-13-2019, 12:32 PM
BigBlockBobby's Avatar
At least you have a little sticking up to grab. May not even need to weld a nut to it if you heat the area around it and turn whats left with vice grips.
BigBlockBobby is offline
post #7 of 15 (permalink) Old 01-13-2019, 12:39 PM
Desertwndrr's Avatar
You should have enough to grab and remove the rest of that bolt. Lucky it didn’t snap flush. My S&S lifter cuffs came with replacement bolts. If you have the ability, check your crank runout and post up your results.
Do yourself a favor and make sure that you have the updated oil pump plate before you put it together.
RGKen and madmat like this.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #8 of 15 (permalink) Old 01-13-2019, 01:05 PM
RGKen's Avatar
I know this doesn't help you now but when I get a bolt that feels like there is a lot of locktight I go back and forth several times as I back it out. May not have worked on that bolt but I've had great success with it. I was also going to mention that you make sure you get the latest oil pumo back plate part# 62400206 if you haven't already lke Desertwndrr mentioned.
madmat likes this.
2018 FLTRXS
RGKen is offline
post #9 of 15 (permalink) Old 01-13-2019, 10:38 PM Thread Starter
Galooch's Avatar
It's the Woods 222 and a Power Vision tuner. The guys at Fuel Moto loaded a map that they say will bring it to somewhere near 110-115 hp and 120 ft lbs of tq. Sounds pretty good to me.
Galooch is offline
post #10 of 15 (permalink) Old 01-13-2019, 10:44 PM Thread Starter
Galooch's Avatar
Originally Posted by Little Wing View Post
ouch.
engine porn lol
[QUOTE=Desertwndrr;4583011]You should have enough to grab and remove the rest of that bolt. Lucky it didn’t snap flush. My S&S lifter cuffs came with replacement bolts. If you have the ability, check your crank runout and post up your results.
I was able to get the bolt out fairly easily. A little bit of heat and some patience got the job done.
Little Wing and BigBlockBobby like this.
Galooch is offline
Sirius Stratus 6 install flg8r71 Equipment-RG 43 02-26-2017 04:55 PM
Buky Assault bars and engine guard install Drednot Controls & Handlebars 19 08-15-2014 05:06 PM
HD Audio iPod Interface Install - 2011 RGC wachuko Do-IT-Yourself 26 12-31-2012 07:30 PM
big time ape hanger install problem LARGECARTRANSPORT Controls & Handlebars 3 07-13-2012 07:01 PM
UPDATE my 5x7 Hogtunes speaker and amp install SKULLZ Aftermarket Accessories 8 04-06-2010 09:45 PM
