103 question - Road Glide Forums
 7Likes
post #1 of 14 (permalink) Old 02-04-2019, 03:35 PM Thread Starter
103 question
I have a 16 rgs thinking about upgrades. Would I be better offdoing a side winder 110 kit or FUELING RACE OIl system with new cams. Which one should I do 1st? Itís just me riding in the mountains no passenger. Bike has the stage one stuff done to it other than that sheís stock. Just looking for a little more power and reliability. Thanks in advance
RFowler is offline
post #2 of 14 (permalink) Old 02-04-2019, 04:13 PM
madmat's Avatar
I don't have an answer for you but I can welcome you to the forum
Welcome from Mass!
18 RGS Bonneville Salt Pearl
madmat is offline
post #3 of 14 (permalink) Old 02-04-2019, 04:42 PM
geo8866's Avatar
Also no answer but welcome to the forum.
geo8866 is offline
post #4 of 14 (permalink) Old 02-04-2019, 05:00 PM Thread Starter
Thank you! Glad to be here
RFowler is offline
post #5 of 14 (permalink) Old 02-05-2019, 06:42 AM
Welcome to the forum, sorry no answer on the question.
FLTRXS18 is offline
post #6 of 14 (permalink) Old 02-05-2019, 08:01 AM
FDR's RGC's Avatar
Cams. You'll notice the difference.
PBSTN likes this.
FDR's RGC is offline
post #7 of 14 (permalink) Old 02-05-2019, 08:13 AM
JacktheBagger's Avatar
Cams and tuner , oil pump upgrade is fixing a problem you don't have .. Nothing wrong with the Feuling or S&S pumps , but there is nothing "wrong" with the pump you have either ..
RFowler likes this.
2011 Ultra
JacktheBagger is offline
post #8 of 14 (permalink) Old 02-05-2019, 09:02 AM
Squidlow's Avatar
103 question
The newer bikes have a good cam plate and pump. Donít replace unless you see damage. Do the bearings that come with most cam install kits and while you have it open, change the tensioner shoes. You might not need to but if itís open no harm for a few bucks.
This was the advice given to me.
Cam support plate and oil pump? Gear or chain?
https://r.tapatalk.com/shareLink?sha...3&share_type=t
RFowler likes this.
Squidlow is offline
post #9 of 14 (permalink) Old 02-05-2019, 09:30 AM
ChromeSpark's Avatar
ps: Welcome to the Tank!
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #10 of 14 (permalink) Old 02-05-2019, 11:28 AM
Thermodyne's Avatar
Neither.
What ever you do, do it all at once.
First, how many miles are on it and second what's the run out on the crank. S&S 111 crate motors are about $6500. If you 103 needs a crank, and you are paying the wrench, building a good 110 can be right there in the same range.
If your crank is good and the miles on it are reasonable, then drop $2600 on a tire shredder kit. It'll put a smile on your face.
Thermodyne is offline
Cam Question Hack73 Engine Related 19 10-01-2016 08:29 AM
Tuner question from noob surfrat2 ECM/Fuel Management systems 7 01-27-2015 10:35 AM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
Lowers question 2013-CVO-110RG Paint & Bodywork Section 10 04-23-2013 07:33 PM
Extended Warranty Question 100edition New Members Welcome Area 13 03-12-2013 11:53 AM
