Have a Power Vision hooked up need to know why this is so high? - Road Glide Forums
 8Likes
post #1 of 15 (permalink) Old 02-19-2019, 05:21 PM Thread Starter
Heavy Metal's Avatar
Why is my Engine Temp so high. 322 degrees? 84 degrees out. Have a 2018 Road Glide Special.
Heavy Metal is offline
post #2 of 15 (permalink) Old 02-19-2019, 05:25 PM
RGKen's Avatar
Attachment 379765
I've used a gun to shoot the temps at the head next to the plug and it's normal to see 300-325 degrees there.
2018 FLTRXS
RGKen is offline
post #3 of 15 (permalink) Old 02-19-2019, 05:32 PM Thread Starter
Okay I will
post #4 of 15 (permalink) Old 02-19-2019, 07:54 PM
Okay I will
You will ?
craigffb likes this.
post #5 of 15 (permalink) Old 02-19-2019, 07:56 PM
HellInABucket's Avatar
Very typical: Once you begin to measure something, you start to become a freak about it.
HellInABucket is online now
post #6 of 15 (permalink) Old 02-19-2019, 08:07 PM
Plan on hooking my power vision up next week if I get time. Just following along all threads for advice.
post #7 of 15 (permalink) Old 02-19-2019, 09:49 PM
Bruce00's Avatar
So true, that's why HD never put an oil temp gauge on bikes
2015 RoadGlide Special
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #8 of 15 (permalink) Old 03-01-2019, 08:15 AM
I have a 2010 road glide with a 107 build did a fueling cam chest and HP oil pump I did install an LED oil temp gauge out of the catalog the temp would run on an84 day around 280 degrees With the fueling assembly now around 240 to 280 depending on how hard I’m riding I had a race engine builder tell me the LED oil temp I had a race engine builder tell me the LED oil temp gauges are garbage who knows
vincem1
scarlet red 2010 RG
vincem1 is offline
post #9 of 15 (permalink) Old 03-01-2019, 08:44 AM
Thermodyne's Avatar
That's just the temp on the head sensor. Down deep near the combustion chamber. Exterior temps will be less.
If it bothers you, put some fans on it.
RGKen likes this.
Thermodyne is offline
post #10 of 15 (permalink) Old 03-01-2019, 09:03 AM
smitty901's Avatar
Nothing to worry about your temps are fine. To much BS out there on head temps vs oil temp ect. I would see 360 at times in rides like rolling Thunder. never hurt a thing. Using the thermal gun is a waste of time . To be accurate it must not be on chrome you have to have it in the exact same place every time the exact distance.
ChromeSpark and Trendkill like this.
smitty901 is offline
Anyone flash power vision and have the idle go high 1500rpm ect and won’t go back dow Heavy Metal ECM/Fuel Management systems 7 01-24-2019 06:17 PM
Power Vision & Power Core- Have You Ever ? Arkie ECM/Fuel Management systems 0 10-16-2018 12:26 PM
power vision find RT Green screen Arkie Map Section 2 10-01-2018 07:15 PM
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
New Dynojet Power Vision CX for H-D fuelmoto Fuel Moto 1 02-22-2018 01:27 PM
