Mouse in my Engine - Road Glide Forums
 9Likes
post #1 of 16 (permalink) Old 02-25-2019, 01:21 PM Thread Starter
Still Grumpy's Avatar
Mouse in my Engine
So... yea, not really. But it sure sounds like one....
My 2018 has developed a Squeaking noise at idle...
It only happens at idle and only after its warmed up ...Its gotten worse in the past 2 weeks.
The noise resignates from the right side of the engine, Almost as if it were coming from inside the air filter. (I have a SE Heavy breather)
I checked the heat shield clamps, floor boards. I tried to wiggle everything and anything that could be loose but found nothing. If i rev the engine it goes away. Its really annoying me .
It almost sound like a squeaky rocking chair ...
I drove by the dealer this past Saturday and asked one of the mechanics to please come out side and hear it out. At first the noise dissappeared (of course) but I asked him to take it for a ride around the parking lot to get it warmed up again Sure enough the squeaking began. He said it sounded to him like it was coming from the primary... Loose chain im figuring.
The bike is approaching 10,000 miles now so its time for an adjustment Im guessing... But wow, thats alot of Squeaking ...
I recently did change the primary fluid. And used a quart of B&M Trick Shift which i read reviews on and is supposedly superperb or our primaries.. Could that be the culprit ?
Anyone has experienced this ?
Still Grumpy is offline
post #2 of 16 (permalink) Old 02-25-2019, 01:31 PM
Thermodyne's Avatar
Take a length of hose and see if you can locate the noise. Just use it like a stethoscope, plastic shop vac hose works well.
You might even want to take the cover off the air cleaner first. I've seen more than a few posts about SE breathers causing noises at idle. I thing the noise was always there, the SE breather just makes it noticable.
Still Grumpy likes this.
Thermodyne is offline
post #3 of 16 (permalink) Old 02-25-2019, 10:20 PM
Desertwndrr's Avatar
I had a squeak in my motor. Turned out that I had a lifter shit the bed and it sent metal particles throughout my motor. Check your oil before you run it any longer.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #4 of 16 (permalink) Old 02-26-2019, 08:11 AM Thread Starter
Well, I dropped it off at the dealer this morning.
If it is the chain I hope they adjust it and cough it up under warranty work..
However i am anticipating them telling me I am due for my 10,000 mi service which would include that adjustment. Am I correct on that ?
My only defense would be that the level of noise it has is not normal...
post #5 of 16 (permalink) Old 02-27-2019, 05:18 AM
chowman63's Avatar
I had a squeaky noise coming from the front part of my motor that drove me nuts. Only at idle and very slow speeds.
I had read another post on here about some one else had this issue. Engine stabilizer bar at the front of the motor was stuck at a angle. Sure enough that’s what it was. Got it loose and siliconed it up and no more sqeak. Not saying that where your sqeak is but just sharing my mouse experience.
Let us know how things turn out.
Stoic Joker likes this.
chowman63 is offline
post #6 of 16 (permalink) Old 02-27-2019, 06:10 AM
RGKen's Avatar
As you can tell so far it could be a variety of things. I had a cam bearing go bad and it sounded like a squeak or chip every so often. Like was stated before if they change the oil they might see little very fine particles of metal that looks like angel dust in the oil and that will let them know there is an internal problem. Hopefully it is just the stabilizer link or something external.
2018 FLTRXS
RGKen is offline
post #7 of 16 (permalink) Old 02-27-2019, 06:37 AM
lil chief's Avatar
I had an annoying squeak on my old bike that appeared while on a road trip. Turned out to be the rubber muffler spacers under the saddle bags. They dried out. The squeak would disappear while riding, but was there during idle squirted a little wd 40 on em and all was good.
Lil Chief
flhman and Rays Road Glide like this.
lil chief is offline
post #8 of 16 (permalink) Old 02-27-2019, 06:44 AM
Stoic Joker's Avatar
I had the same issue with my 10 about a year ago.
chowman63 likes this.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #9 of 16 (permalink) Old 03-05-2019, 04:05 PM Thread Starter
Thermo,
thanks for the advise. If it were the SE intake Wouldnt the squeak occur all the time ?
Its happening only after engine has warmed up and bike has been driven .
I took it to the dealer and all they did was drain the 3 fluids and replaced with new.
They claimed my Primary fluid level was extremely low and was the cause of the squeaking.
Thankfully no metal shavings were found in either of the 3 fluids.
However, after the ride home , the squeak returned...
Apparently they did not take the bike out for a test run even after I informed them that the squeak happens after the bike has been driven a short while.
post #10 of 16 (permalink) Old 03-05-2019, 04:26 PM
Thermodyne's Avatar
Originally Posted by Still Grumpy View Post
Thermo,
I can't say. Never actually dealt with the M8 TB squeaker. But I have read about it a few times over the last six months.
The position of the throttle blade changes as the motor warms up and the battery tops up, so the blade is a few steps closer to being closed on a warm motor. So it is different, cold to warm.
Cold start engine RPM on 107 engine 96349 Engine Related 3 11-07-2017 07:22 AM
HD 2007 - 2013 High Engine Temperature Behavior Explained ironmark Troubleshooting for Road Glides 22 11-12-2016 08:34 AM
Retuned...again apgharleymech Dyno Results 51 05-04-2016 01:01 AM
Put a new engine in the bike ironmark *General Road Glide Discussions/Pictures 12 12-03-2015 08:56 PM
Buky Bars Engine and Saddlebag Guards... nice! sdlakerfan79 *General Road Glide Discussions/Pictures 11 01-15-2014 08:44 AM
