SE manual primary adjuster - Road Glide Forums
 14Likes
post #1 of 18 (permalink) Old 03-14-2019, 07:44 AM Thread Starter
JacktheBagger's Avatar
Anyone using it ? Had the Hayden in and removed it after several people had it come apart ..
2011 Ultra
JacktheBagger is offline
post #2 of 18 (permalink) Old 03-14-2019, 08:12 AM
eddienelson's Avatar
I just replaced mine with the stock automatic tensioner. Didn't see the manual one till after I had already replaced it. The stock tensioner with just under 30k miles looked good. I could see where the rollers of the chain were just starting to make contact with the shoe. Actually I could hear it but no clunking of the chain I hear people talking about. Just a little noisier then usual. I would have no problem trying the SE tensioner.
When I installed mine I jacked the back tire up off the ground and put the bike in 6th gear and rocked the back tire back and forth. I had measured the chain tension before and after I did this. I cant remember but I think it tightened up to about 5/8th of an inch in slack. (not sure about that but I know it was in speck to the manual.) I would think the manual would be the same way. The main thing Ive read is to not get it too tight because of stress on the trans bearing.
2016 RG Custom Vivid Black
eddienelson is offline
post #3 of 18 (permalink) Old 03-14-2019, 09:18 AM
RGKen's Avatar
I ran it for several thousand miles in my Skunk after I installed the 120 but I also ran the stock auto one for the first 20k or so of that. Must have put about 27k on the SE manual one. I believe the stock auto adjusting one is actually fine and has been for some time. Just one of those things that had some issues when it first came out and the MoCo solved the issue with an upgraded part and the after market guys just kept the old stories going to sell their parts. Don't blame them really as that is how sales works.
1st Sgt and Jacksprat56 like this.
2018 FLTRXS
RGKen is online now
post #4 of 18 (permalink) Old 03-14-2019, 09:59 AM Thread Starter
Never have had an issue with the stock auto tensioner , every time I go in the primary , it's good , but I always pull it to remove the tension for grits and shiggles , with almost 70 thousand the shoe still has lots of life left ..
1st Sgt, RGKen and Jacksprat56 like this.
2011 Ultra
post #5 of 18 (permalink) Old 03-14-2019, 05:54 PM
ChromeSpark's Avatar
@JacktheBagger what lubricant might you run in there?
"It's a motorcycle, itīs not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s**t your pants every now and then."
ChromeSpark is offline
post #6 of 18 (permalink) Old 03-14-2019, 11:15 PM Thread Starter
I have run quite a few different loobs , the Harley , Redline , Delo 15-40 , and currently valvoline non syn 5-20 , I put a BDL clutch pak in a couple years ago and they recommended light non syn motor oil ..
No issues with any of them , altho I thinketh the Delo was too slippery and caused some clutch slipping ..
2011 Ultra
post #7 of 18 (permalink) Old 03-15-2019, 07:37 AM
Mike U's Avatar
JTB, I used to run the Hayden but changed it out for the Baker Armored Attitude Adjuster.
The Hayden got very tight and dug grooves into the shoe.
So far The Baker is holding up very well. A quality piece from a Exceptional Company.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #8 of 18 (permalink) Old 03-16-2019, 05:31 PM
I put the Hayden tensioner in a few years ago and had the shoe break apart. I contacted Hayden about it and they told me that they "updated" the springs. The original version had a double spring, spring inside a spring. The "updated" design only had 1 spring. They sent me the "new" design and I reinstalled it and it's been great since. I'm currently doing a 124 motor swap and I will reuse the Hayden but I did replace the shoe only because I'm replacing everything that can be replaced as I take it apart to do the swap
post #9 of 18 (permalink) Old 03-16-2019, 06:03 PM Thread Starter
Must have been you that I recall saying the spring pack was updated , I have the two spring set up .. Free as I recall ?? May contact them and get the spring , because I really like it ..
rlaf75 likes this.
2011 Ultra
post #10 of 18 (permalink) Old 03-16-2019, 06:21 PM
Hey Jack. Isn't that the freak @rlaf75 that runs a car tire on his bike. You can't listen to him! He's retarded... FREAK!
JacktheBagger and RGKen like this.
primary chain adjuster StGhost Engine Related 4 10-14-2017 08:52 AM
Primary chain adjuster GlideRide Engine Related 6 10-01-2014 08:39 PM
Baker Atitude Adjuster - manual primary chain adjuster modot66 Parts for Sale 1 06-19-2014 03:19 PM
Who's running SE Manual Primary Chain Adj. Hillglide Engine Related 17 04-16-2014 11:27 PM
SE pro Manual primary chain adjuster Jeff Clark *General Road Glide Discussions/Pictures 11 03-18-2014 04:42 AM
