Final Drive Belt Replacement - Road Glide Forums
 7Likes
post #1 of 12 (permalink) Old 04-04-2019, 10:09 PM Thread Starter
92Dinoglide's Avatar
Needing to replace belt after mine broke in the driveway.
Seeing a lot and ranging from 140-230$
What is the best for the price?
Thank you to all!
92Dinoglide is offline
post #2 of 12 (permalink) Old 04-04-2019, 10:13 PM
Clutch1's Avatar
Iíd say the Harley belt. I put 70,000 miles on mine before I replaced it just cause I felt I should.
04 Road Glide
1st Sgt, madmat and geo8866 like this.
Clutch1 is offline
post #3 of 12 (permalink) Old 04-05-2019, 12:15 AM
I just replaced mine with just shy of 60k miles on it. It still looked good but I didn't want to chance it with the new motor. I used a belt from JP Cycles. It's made by Gates. It was about $150ish. My local dealer wanted $300 for a HD replacement
1st Sgt likes this.
post #4 of 12 (permalink) Old 04-05-2019, 12:18 AM
JacktheBagger's Avatar
Harley belts easily go beyond a 100 , luck of the draw with that tho' , any rocks or road debri can make short life of any belt .. Never used any other belt myself .. Best I got was 150 on my 88 Tour Glide and it ran out of adjustment and had several teeth gone .. Have a new one on the shelf , when I change this back tire at around 85000 , it will go on then ..
1st Sgt and Little Wing like this.
2011 Ultra
JacktheBagger is offline
post #5 of 12 (permalink) Old 04-05-2019, 03:56 AM
smitty901's Avatar
HD factory belt is as good as it gets. No common to replace one. Find the reason first so you don't destroy what ever you go with. Factory belts go an easy 80K to 100K
1st Sgt likes this.
smitty901 is online now
post #6 of 12 (permalink) Old 04-05-2019, 10:29 AM Thread Starter
I have 60k on my Ď92í Ultra and didnít know if a python belt or some after market will last longer then stock....
What about DIY: is there anything tricky or speacialty tools Iíll need? Has anyone done it then self? HD wants 800$ to do it, I said F that I know I can do it!! I just never have, HD said it would take 4hrs for them??!??
post #7 of 12 (permalink) Old 04-05-2019, 10:38 AM
Clutch1's Avatar
If you are replacing the sprockets, the front sprocket requires and very deep socket to get to the nut. I picked up a socket for that job on eBay for $45. Other then that regular tools are all that is needed.
04 Road Glide
Clutch1 is offline
post #8 of 12 (permalink) Old 04-05-2019, 06:49 PM
you have to pull the primary completely , the rear tire and swing arm , I have done it a couple times , it's a PITA , but do it if you are half way mechanically inclined ..
2011 Ultra
post #9 of 12 (permalink) Old 04-08-2019, 06:04 PM
Banned
Over 90k on my 99 heritage w/original belt and over 50k of them miles were with a 120" motor.Belt still looks good i never beat on it tho.I myself would spend the extra cash and get HD belt
Mike
post #10 of 12 (permalink) Old 04-08-2019, 06:19 PM
Banned
4 hrs..isnt bad i never did one myself but i know what it takes.Lotta chit to take apart,and that compensator sprocket nut is got sum serious ass torque on it,you better have a nice heavy duty breaker bar.But if you can do it yourself dig into it i like fixing my own shit, even if it means breaking something once in awhile been there done that and probably will do it again LOL good luck
Mike
Drive belt replacement Slider1156 Engine Related 7 11-16-2016 09:41 AM
Every fourth tooth half missing on final drive belt ccallahan Tech Area 3 07-09-2015 09:19 AM
Final drive belt question...... Nevadasun *General Road Glide Discussions/Pictures 11 07-08-2015 07:54 AM
Final drive belt replacement. ccallahan Do-IT-Yourself 10 02-15-2015 12:09 PM
belt drive specifics replacement 1340 miriottina Tech Area 9 01-13-2015 02:49 PM
