Spark knock after cam install & tune - Road Glide Forums
post #1 of 4 (permalink) Old 04-08-2019, 05:55 AM Thread Starter
SJA66's Avatar
2015 RGS, Cyclerama 570-2, S&S lifters and Quikee rods, had it dynoed, finally got to do an extended ride today and noticed what sounds like a spark knock when I roll the throttle under a load, it goes away after the RPMs get past 3200, sorta sounds like some gravel going thru the fender. Is this from the cam, lifters, rods, gas or maybe tune. any suggestions would be great, I want to get this resolved and really not sure where to start.
SJA66 is offline
post #2 of 4 (permalink) Old 04-08-2019, 05:54 PM
Banned
If you had it dynoed that shouldn't be going on, are you maybe lugging that motor before you wack it.Is it doing it in 1st gear ? Just thinking out loud here,i myself would bring it back to yer dyno guy and tell him whats going on.
Mike
post #3 of 4 (permalink) Old 04-16-2019, 01:24 PM
army12b's Avatar
Agreed, it's most likely the tune, don't wait take it back to the tuner or at least call him, just probably needs some tweaking and will be all good.
army12b is offline
post #4 of 4 (permalink) Old 04-16-2019, 03:16 PM
Thermodyne's Avatar
Needs to have some spark backed out of it at lower rpms. Its a common problem with pressure (torque) cams.
Many dyno operators really only have one goal, maximize torque and HP results. For street driven vehicles you often have to leave some of that power on the shelf, and tune for drivability.
Thermodyne is offline
Milwaukee 8 spark knock 17RoadGlideSpc Engine Related 40 10-21-2018 07:16 AM
Survey request: 103s with spark knock StriderJim *General Road Glide Discussions/Pictures 33 01-29-2012 08:52 AM
Is anyone having trouble with Bad Spark Knock? Dandy1 *General Road Glide Discussions/Pictures 66 08-24-2011 06:49 PM
UPDATE my 5x7 Hogtunes speaker and amp install SKULLZ Aftermarket Accessories 8 04-06-2010 09:45 PM
