110" or go BIGGER? - Road Glide Forums
 4Likes
post #1 of 14 (permalink) Old 04-26-2019, 11:37 AM Thread Starter
Wildman's Avatar
110" or go BIGGER?
I've been out of the RG world for a few years and am just looking at all the new BIG jug kits available now. Before I had to take a break from my bike to install a 110" kit on my 2011 RGU 103" engine you had to have your case machined. Now you don't so it is a great way to increase my displacement without doing any machine work.
But if I am going to take my engine down anyhow should I go bigger? Most of my riding is sole riding but may be two up some of the time. What am I looking for out of this? A little more power for climbing mountain passes and passing traffic when I have to. Right now the only work I have done is new cams, air filter & exhaust. I am running a Power Vision tuner but don't have the auto tune feature yet.
My ex had a CVO Switchback right before we split up and the 110" in it had been messaged some and that thing was a power house. Just want to make sure before I dump money into my engine that I am going to be happy with it.
WILDMAN
1997 Jeep TJ SE
2011 FLTRU Road Glide Ultra
2009 Buell XB12R Firebolt
2008 Honda TRX700XX
Wildman is offline
post #2 of 14 (permalink) Old 04-26-2019, 11:56 AM
Thermodyne's Avatar
A sub $3000 SE tire shredder kit will give you 120/120ish from 110 inches depending on your pipes and tuner. You can install it at home, with the lower end in the scooter. But you'll need a good wheel set. If it needs wheels and a plate and pump, now your getting close to crate motor money. Your there if you are paying the wrench. And smart money says all 103's need new wheel sets, sooner or later, later just costs more.
A kit 110 will make more power than a S&S 111 using the oem takeoffs. Same with the SE124. The S&S 124 will make about the same as the 110 SE-TS kit using the oem take offs. All of the crate motors will benefit from larger the throttle bodies and injectors like come with the SE-TS kit.
So its 6 of one and half a dozen of the other. If you do your own work, the 110 kit is cheaper horse power. if you pay the wrench, then the S&S motors are prolly the way to go. The SE 120 is the least expensive crate motor, both for the motor and for the install, but I'm not going to recommend that motor to anyone.
Be aware, that past 120/120 you'll start paying driveline tax. The comps aren't up to living with 75/75. The clutch isn't really up to the task of holding 120 hp, and little things like replacing the rear axle adjuster cams costs an arm and a leg.
Wildman and gplatt58 like this.
Thermodyne is offline
post #3 of 14 (permalink) Old 04-26-2019, 12:03 PM
JacktheBagger's Avatar
With the low miles that you have on the bike , the weak spot on TC's is air , you got cams , get S&S to either work your heads ( about a grand ) or get a set of their heads ..
The other weakness is wheels ( the flying kind ) for decent upgrades ...
I agree with Thermo on everything .. Mine is at 70 thou now and I am already looking in the direction I want to be in a couple years when this one needs replacing ..
Wildman likes this.
2011 Ultra
JacktheBagger is offline
post #4 of 14 (permalink) Old 04-26-2019, 12:10 PM Thread Starter
Wildman's Avatar
I'll be doing my wrenching. I'm not a sure I know what you are talking about when you say Wheels, Plate & Pump? I'm going to guess the plate is the cam plate and the pump is the oil pump. When I did the Woods cams before I replaced the cam tensions I think but didn't do anything else.
Is the SE-TS kit the best in the market? What about the Fuel Motto 110" kit? Or other companies?
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #5 of 14 (permalink) Old 04-26-2019, 12:20 PM Thread Starter
Wildman's Avatar
Okay the flywheel breaking. Some of this old stuff is coming back to me. So when I have it torn down doesn't it make better sense to pull the case and have these weak areas fixed? I know I have low miles on it and should just get on it and ride but I also have the itch to tinker on it. It has been too long since I was able to work on stuff so I am looking forward to getting back at it.
I remember there were kits to change the flywheel bearings to Timken bearings but you had to have your case machined? I think.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #6 of 14 (permalink) Old 04-26-2019, 12:29 PM Thread Starter
Wildman's Avatar
When I did the cams.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #7 of 14 (permalink) Old 04-26-2019, 12:37 PM
yeah you can do the timken conversion for the flyin wheels , what I was meaning , with only 8000 miles on the bike , I'd leave the bottom alone unless you just wanna go there .. Flywheels should be in great shape still .. I don't upgrade just to upgrade , I will wait for sumpthin' to let go usually or do it when I feel the mileage is approaching a squatting situation ..
For now , if you just got the heads done , you would be good to go IMO for a long while mileage wise ....
Unless ya just wanna .....................
2011 Ultra
post #8 of 14 (permalink) Old 04-26-2019, 12:49 PM Thread Starter
Wildman's Avatar
All I might do to start with is fix my exhaust with a 2-1-2 system and get rid of my duals.
I was looking at upgrading my engine before I had stopped riding. I am one of those guys who can't leave anything stock.
I would just hate to be out somewhere and have something take a dump on me. I try to fix things BEFORE the fact.
In the next 3-4 years I am hoping to start traveling and am going to build a toyhauler that my bike & Jeep while go in. The idea is to travel around the USA and when I stop in an area I hit some wheeling spots but also go sightseeing on the bike. So if I was to have MAJOR engine issues I would be screwed. I'll only have basic tools and stuff with me. I'm thinking I'll spend 8 months of the year traveling and come home for the summers. I don't enjoy the cold winters here in the mountains of WA like I use to.
So I'd like to try and fix all the trouble areas now so my bike can be as trouble free as possible.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #9 of 14 (permalink) Old 04-26-2019, 01:10 PM
Thermodyne's Avatar
Take a look at what you get with the tire shredder kit. Then price the other 110 kits along with the extras that come in the TS kit. It really is a pretty good deal.
The TS kit is $2550ish.
The Fuel moto kit is $2900
plus the head work $880
plus the throttle body and injectors $600
So you'll have almost $4400 in that kit and stuff to go with it.
post #10 of 14 (permalink) Old 04-26-2019, 01:15 PM Thread Starter
Wildman's Avatar
This is the only one I am seeing for my year bike. I know they offer the TS kit for the 2014-17 but I'm not finding it for my year.
https://www.harley-davidson.com/stor...ck-highlighted
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
Bigger mirrors edimean22 Aftermarket Accessories 10 01-31-2019 03:20 PM
Need bigger mirriors edimean22 *General Road Glide Discussions/Pictures 17 07-02-2018 02:36 PM
110" to 113" gnturboray Engine Related 27 11-16-2013 05:24 PM
bigger wheel Jasondoow Wheels and Tires 6 09-16-2013 03:41 PM
