Battery charge line got caught in back wheel - Road Glide Forums
 5Likes
  • 2 Post By RGKen
  • 2 Post By Ohiobellboy
  • 1 Post By skratch
post #1 of 7 (permalink) Old 05-19-2019, 07:35 AM Thread Starter
tazza56's Avatar
So my battery trickle charge wire/plug fell against my back wheel and sheared off.
In turn my cigarette lighter/charger stopped working as well.
From what I understand the trickle line is wired into this harness.
I checked my fuses all are fine. Are there any other fuses Iím overlooking?
tazza56 is offline
post #2 of 7 (permalink) Old 05-19-2019, 08:03 AM
RGKen's Avatar
I checked my fuses all are fine. Are there any other fuses I’m overlooking?
It's just a pigtail that is connected to the battery so just buy a new pigtail, remove the old one, and install the new one. My guess is that your cigarette lighter stopped working because you did blow a fuse. Look at the accessory fuse closer and it is not uncommon that you will not be able to see a break and I would test continuity. Each fuse has metal pins in the back end of the fuse that I just touch with the probes from my multimeter to ensure the fuse is working. It can be done with the fuse in it's slot so you don't even nee to pull it.
Let us know if you find it.
Bobinator and ChromeSpark like this.
2018 FLTRXS
RGKen is online now
post #3 of 7 (permalink) Old 05-19-2019, 08:51 AM
Ohiobellboy's Avatar
I'm under the impression that on the newer bikes they're built into a harness. I know mine doesn't go straight to the battery like on my '11 RGU did. Like Ken said, look for a fuse. You're also going to have to trace what's left of the wire to see where it goes.
RGKen and ChromeSpark like this.
A.K.A OBB
Ohiobellboy is offline
post #4 of 7 (permalink) Old 05-19-2019, 12:36 PM Thread Starter
tazza56's Avatar
Hey guys,
Thanks for the info. On 15 RGS the charger is wired to the harness and seem to be buried deep inside the bike.
I changed all the fuses that relate to the battery. I can easily put a pigtail directly to the battery but that still leaves me with mo lighter/charger on the clutch side of the bike. So my question remains: does anyone know where the lighter/charger fuse might b or is it combined with another fuse thatís not named on the fuse box.Thanks
R
tazza56 is offline
post #5 of 7 (permalink) Old 05-19-2019, 03:38 PM
skratch's Avatar
if you go to the Harley service information portal, you can pull up the wiring diagrams for your bike.
https://serviceinfo.harley-davidson....cle/lookupForm
RGKen likes this.
skratch is online now
post #6 of 7 (permalink) Old 05-19-2019, 07:48 PM
twowheeladdict's Avatar
Sorry that happened. Did you cut back the rest of the wire and tape it off so the positive can't make a connection with anything and short out?
There is a 20A fuse in he fuse block that the Battery Tender wire runs through.
I did a real quick look at the wiring diagram and it looks like if a fuse is blown for the cigarette lighter other things shouldn't be working as well. Did you check the cigarette lighter with a voltmeter?
Good Luck.
2018 Road Glide Special, 2018 Moto Guzzi V7III Carbon, 1975 KT250 Trials
twowheeladdict is online now
post #7 of 7 (permalink) Old 05-20-2019, 07:16 PM Thread Starter
tazza56's Avatar
Hey Twowheel you hit it on the head I changed the 20 fuse and bingo! The lighter worked.
I had looked at this fuse and it looked fine but I guess just putting eyes on it is not a good test.
Going to splice another plug into the battery charge line and hopefully that should handle it.
Thanks so much for the info.
tazza56 is offline
Front Wheel ABS Sensor Issue smittys69 Wheels and Tires 2 05-09-2014 12:53 PM
Question on switching back to stock rear wheel hoosierboarder Wheels and Tires 4 04-16-2014 06:55 AM
Newbie rear wheel question Bigdubya Wheels and Tires 0 09-13-2012 08:08 PM
Wheel Special Swagzilla Wheels and Tires 10 05-14-2012 12:30 AM
21" wheel with stock back wheel Cybrrmage Aftermarket Accessories 16 11-12-2011 10:50 PM
