103 hd stage 4 smokes on hard acceleration - Road Glide Forums
 6Likes
post #1 of 13 (permalink) Old 05-23-2019, 11:04 AM Thread Starter
I'm hoping someone could shed some light on this topic. Other riders tell me that my bike smokes when I get get on the throttle hard. What could this be?
pryda is offline
post #2 of 13 (permalink) Old 05-23-2019, 11:39 AM
You need to pull that motor and install a 120ST, that is how I would correct this problem.
madmat likes this.
beerhunter is offline
post #3 of 13 (permalink) Old 05-23-2019, 01:09 PM
Rob-B's Avatar
Sounds like piston rings.
My experience with smoky engines are - Intake valves or Piston Rings.
Either way - major work is required, so do the whole thing and do the work once.
If you think about it - intakes open when the cylinder is going down - a vacuum of sorts. Excess clearance or bad stem seal causes a leak.
Exhaust valves always open against a positive pressure - they "burn" more than they develop minor stem seal leakage.
Loose piston rings suck oil mist or vapors in during the intake (vacuum) stroke. And - the more you're pumping, the more that burn occurs - your smoke under acceleration.
New engine or rebuild fixes all that.
I'd find the excuse to go big bore, but that's just me.
Rob-B is offline
post #4 of 13 (permalink) Old 05-23-2019, 01:32 PM
wevsspot's Avatar
What color is the smoke? Black, blue, gray, pink?
Does it smoke out of both cylinders or just the front or rear?
wevsspot is offline
post #5 of 13 (permalink) Old 05-23-2019, 03:18 PM Thread Starter
It's gray one comes from the front cylinder.
pryda is offline
post #6 of 13 (permalink) Old 05-23-2019, 03:20 PM Thread Starter
How much longer can I ride it before it blows?
pryda is offline
post #7 of 13 (permalink) Old 05-23-2019, 04:24 PM
08Zinc's Avatar
What motor is it? I had a 103 with a stage 4 kit in my 2011 and it went through 4 sets of pistons in just under 2 years before selling the thing back to the stealer. They never could get it to run right. The second owner took it to his shop and they couldn't get it right either. 3rd owner now taking the motor back to stock configuration. Hope yours isn't like my experience. My whole saga with that is posted here if you do a search under my name and Stage 4. I loved the power, but it was NOT worth it.
Blessings, Zinc -
08Zinc is offline
post #8 of 13 (permalink) Old 05-23-2019, 07:13 PM
I would point to the rings.
ALMOONEY is offline
post #9 of 13 (permalink) Old 05-24-2019, 03:29 AM
Black smoke is fuel, blue smoke is oil. If the smoke is black you have a tuning problem and can be cured with a good tune. Blue smoke may be a bit more costly, First do a compression test and see what the compression is. If the compression is low then squirt some oil into the cylinder and test it again if the compression goes up then there is a problem with the rings if it stays the same then it may be the valves. Also in the top of the cylinders in the rocker box is the crankcase vent and if the butterfly valve is malfunctioning then you will get more oil into the intake causing the bike to blow blue smoke. If the bike blows blue smoke when you first start it for the day it is caused by oil seeping into the cylinder from a bad valve or valve seal. Also IMO the stage 4 is a waste of money a good cam and exhaust upgrade with a good tune will give you a good dependable touring bike.
post #10 of 13 (permalink) Old 05-24-2019, 11:52 AM
Find a shop who knows how to do a "cylinder leak down test". This test will help you trouble shoot your problem.
Buzzy likes this.
ALMOONEY is offline
STAGE 3 Upgrade skillz213 Engine Related 16 05-24-2019 05:06 AM
107" stage 2 with true duals Livewire Dyno Results 6 01-05-2019 05:04 AM
Thoughts about Stage I and other upgrades paid4c4 *General Road Glide Discussions/Pictures 2 02-14-2018 12:34 PM
Full SE vs VH Exhaust System w/ Stage 2 Sound System RoadWolf1172 Intake and Exhaust 23 12-26-2017 01:33 PM
Difference between Arlen Ness Stage I/II danhubbardsr Intake and Exhaust 0 04-05-2013 04:31 PM
