M8 -Fluid Transfer solution Question - Road Glide Forums
post #1 of 3 (permalink) Old 06-11-2019, 11:44 AM Thread Starter
Still Grumpy's Avatar
Hello all -
Earlier today I posted this question in another OP's thread but just realized it was a thread from January with no replies since and so my question may be overlooked.
Here is a copy of my question :
For those that have replaced the factory pushrod with the Gregg William's version can you please let me know if you ran into any snags when doing so ? Is the swap as easy as it looks ?
Please let my know any "possible " issues i may encounter when doing this.
I ordered mine this week and will be swapping it out soon.
Do i need to drain the tranny fluid before pulling out the stock pushrod ?
thanks guys. -
Still Grumpy is offline
post #2 of 3 (permalink) Old 06-11-2019, 12:47 PM
Originally Posted by Still Grumpy View Post
Hello all -
thanks guys. -
There is a video out there somewhere how to do it. All the person did was take off primary cover, remove snap ring, remove rod, install new rod, new snap ring.
I had thought about doing this, but for less than half the price, now HD has the vent kit that is supposed to fix this - seems people are having success with that.
I'm sure someone will post up the vid.
Edit:
Found it:
2017 Hard Candy Hot Rod Red Flake M8 FLTRXS Road Glide Special. Stage III with *lots* of other goodies.
msquad is offline
post #3 of 3 (permalink) Old 06-11-2019, 01:21 PM Thread Starter
@msquad
thank you for the video.
Yes I had seen it. Looks too simple..
Kinda was the reason i asked if someone that has done it ran into any issues. or if it truly is that easy.
