Spark Plugs and Spark Plug Wires for M8 - Road Glide Forums
 14Likes
post #1 of 26 (permalink) Old 06-19-2019, 07:32 PM Thread Starter
Heavy Metal's Avatar
What’s the best Spark Plugs and Spark Plug Wires for Milwaukee 8’s, and what are you using?
Heavy Metal is offline
post #2 of 26 (permalink) Old 06-19-2019, 07:37 PM
smitty901's Avatar
Standard factory plugs and wires work just fine.
smitty901 is offline
post #3 of 26 (permalink) Old 06-19-2019, 07:41 PM
RGKen's Avatar
Originally Posted by Heavy Metal View Post
Whats the best Spark Plugs and Spark Plug Wires for Milwaukee 8s, and what are you using?
Nothing wrong with the stock plugs and wires. You can change the plugs out every 10k miles and still come out cheaper than buying iridium plugs in the long run. I do like the SE plugs wires because of the color choices.
smitty901 likes this.
2018 FLTRXS
RGKen is offline
post #4 of 26 (permalink) Old 06-20-2019, 06:11 AM Thread Starter
How about 12MM twisted Wires?
post #5 of 26 (permalink) Old 06-20-2019, 07:33 AM
Trendkill's Avatar
For what reason?
2018 Road Glide Special in Bonneville Salt Pearl - Stage II Power, SVT Boneshaker exhaust
Trendkill is offline
post #6 of 26 (permalink) Old 06-20-2019, 09:33 AM Thread Starter
Mainly keep flow to spark plugs
post #7 of 26 (permalink) Old 06-20-2019, 09:37 AM
Thermodyne's Avatar
First, with the need to remove the tank, changing plugs is a bigger deal than it used to be. Second, now that the MoCo uses pazio knock sensors and has kicked that ion voodoo to the curb, there will be less issues with wires.
4 NGK iridium plugs is less than $40, a lot less than the MoCo wants for 4 SE iridium plugs. Less by half.
As for the wires, the secondary voltage is nothing to get excited about, so no need for anything special. OEM wires will be fine. If it turns out the M8's chafe the way twin cams did, just buy $2 worth of armor sleeve. It'll work just as well as $100's worth of 11mm hi performance nito proof 1 million volt race wire guaranteed to give you 10 percent more power.
You really shouldn't even need to think about wires for 50-60K miles.
Well, unless you feel the need for a set that matches the lightning bolts painted on your boots.
smitty901, RGKen, RFG7680 and 1 others like this.
Thermodyne is offline
post #8 of 26 (permalink) Old 06-21-2019, 04:22 PM Thread Starter
I was getting the fat one 12MM Twisted yeah over $100 but my bike deserves it LOL. Take me 5 days week 50 miles to work 50 miles home LOL. Seriously I like the look kinda stands out and looking at Harley ones well what’s the difference price wise. LOL. As far as plugs thinking of NGK Iridium CR9EIX. Not sure are the CR9EIX all same or is there difference in them?
post #9 of 26 (permalink) Old 06-21-2019, 04:55 PM
From the numbers on the HD spark plug boxes, it looks like the 6R10s are the Champion RG6HCCs
File Type: jpeg E0A9FC21-CEBB-4EE4-9C01-E8FC515E2542.jpeg (16.5 KB, 20 views)
2019 FLTRU
Road-dawgs1 is offline
post #10 of 26 (permalink) Old 06-21-2019, 08:51 PM Thread Starter
What about NGK Iridium CR9EIX
