AIM Light Force Slave Cylinder - Road Glide Forums
 13Likes
post #1 of 18 (permalink) Old 07-07-2019, 04:34 PM Thread Starter
BH#103's Avatar
Anyone running one of these on their M8? Good, bad, ugly, what's the verdict on install and outcome?
jimAZ likes this.
"SLIVER"
BH#103 is online now
post #2 of 18 (permalink) Old 07-07-2019, 04:45 PM
Little Wing's Avatar
i had an indy do it with my help lol in lieu of getting the free warranty repair.
didn't have to remove the head pipe but had to loosen the crossover.
i pulled the pipe away from the transmission while he worked the cover off.
off with the old, on with the new, then used syringe to push the fluid up into the reservoir.
used the new fluid from HD
lot less force required to move the clutch lever (2-fingers)
a little more friction zone, but still kinda strange feeling when shifting.
in my opinion, the updated spring on the basket side would prolly make it feel right.
your '19 prolly has the stronger clutch spring in it.
BH#103 likes this.
Little Wing is offline
post #3 of 18 (permalink) Old 07-07-2019, 04:57 PM
jimAZ's Avatar
Installed on mine - a bit of a PITA to install (hard as hell to get enough clearance to get the cover off) but LOVE the result. The friction zone is way better, and just a lot more pleasant to ride in any kind of traffic.
BH#103 likes this.
Hello from Arizona
2018 RGU - First Harley, Long time Rider
jimAZ is offline
post #4 of 18 (permalink) Old 07-07-2019, 05:16 PM
RGKen's Avatar
I actually can't believe you missed the 2 long threads about this that were the main topic for a while. Lol!
One thread had to do with the clutch actuator recall that turned into an AIM thread.
I did mine while I did my cam swap so I already had the exhaust removed which made the install simple. I used a syringe as mentioned above to push the fluid in which made it simpler in my opinion. The only problem was that the pull was so light I kept thinking I must have air in the system and kept bleeding it. Finally I took the derby cover off to see if I had plate movement which I did. All was good when I put it all back together and he pull is so light. 2 fingers light in fact! Makes it much mo betta in traffic. I highly recommend it.
BH#103 likes this.
2018 FLTRXS
RGKen is online now
post #5 of 18 (permalink) Old 07-07-2019, 06:32 PM
gldlver's Avatar
Easy install, made a world of difference
loosen up the entire exhaust system front to back I had no issues getting cover out
BH#103 likes this.
gldlver is offline
post #6 of 18 (permalink) Old 07-07-2019, 06:43 PM
Thermodyne's Avatar
I run the Lightforce, would never go back to the harley cylinder.
The light force cylinder and a damper shim from a 19, make the 17 -18 clutches almost perfect.
RGKen and BH#103 like this.
Thermodyne is offline
post #7 of 18 (permalink) Old 07-07-2019, 07:25 PM
I have had on for about 5 months, only about 4K miles. Absolutely love it, definitely better than stock. I will be putting about 10k miles on the bike in the next 3 months, guess I will really know after that.
BH#103 likes this.
post #8 of 18 (permalink) Old 07-08-2019, 09:12 AM Thread Starter
BH#103's Avatar
I've heard about enough outta ya!
RGKen likes this.
"SLIVER"
post #9 of 18 (permalink) Old 07-08-2019, 09:17 AM Thread Starter
BH#103's Avatar
Appreciate all your input, gonna order one today!
"SLIVER"
post #10 of 18 (permalink) Old 07-08-2019, 09:36 AM
RGKen's Avatar
Bull$#!t!!!! I'll tell you when you've heard enough outta me!
BH#103 likes this.
2018 FLTRXS
RGKen is online now
