Top end noise - Road Glide Forums
post #1 of 4 (permalink) Old 07-12-2019, 09:45 AM Thread Starter
rely!'s Avatar
Top end noise
Trying to chase Down top end noise I installed the rocker lockers that seemed to help a little but when motor is hot it sounds like sowing machine, oil is amsoil also noticed some wear on the rocker housing, one rocker has .012 thousand and other .015 any suggestions thanks in advance
rely! is offline
post #2 of 4 (permalink) Old 07-12-2019, 12:47 PM
Thermodyne's Avatar
The rocker supports do wear out. Shafts too. Peening the bores helps for a short while, but they loosen back up fairly soon. Some of the aftermarket supports are sloppy loose out of the box. Drill in split is prolly the only sure fix.
Thermodyne is offline
post #3 of 4 (permalink) Old 07-12-2019, 11:14 PM
Top end noise is a common thing. When you do cam and or intake upgrades you will hear more noise. Most of the noise comes out out the throttle body and it really isn't anything to worry about. What year is your bike?
post #4 of 4 (permalink) Old 07-14-2019, 11:54 AM Thread Starter
rely!'s Avatar
its a 2015 stock bike except slip ons with about 25000 miles, any suggestions for rockers and supports thinking about just changing them as I will be doing cams over the winter
rely! is offline
