Cam spec question - Road Glide Forums
post #1 of 19 (permalink) Old 06-19-2013, 08:18 AM Thread Starter
Cam spec question
I have my combo figured out....I think LOL
Pushrods-Fuel Moto (Smith Bros)
Lifters-Woods
Cam-Andrews 57h-Tman 555tq or Black Widow BW55
I'm no cam expert BTW.
I attached an image that shows the specs of the various cams.
Can anyone tell me which of these cams will be more low end, more upper range, more even accrossed the board, better mileage etc.
I don't really understand overlap in conjuction with the other specs, lift and duration etc.
My combo before cams is: Fullsac x Pipe, Jackpot Dyno Tuned mufflers, Fuel Moto Air Cleaner and a Power Vision with Autotune (bought through Fuel Moto).
All parts are just off of my 2012 E-glide I traded on the R-Glide.
So as of right now nothing is installed, I want to do it all at once.
I want to order ASAP because right now the beast is all stock and that SUCKS.
I typically ride 2 up for long distances, but when local ride one up.
I tend to drop to 5th if anywhere under 70 (stock) and do tend to crank the throttle pretty hard if I do drop a gear or two
I don't have any plans right now to do anymore work, but down the road I may, which would include head clean up and possibly .30 HG nothing crazy.
I don't want to build something that when heading out on a trip I have to worry about anything other than riding.
Thank you,
KO
2013 Road Glide Ultra Midnight Pearl
Torqueinc .510 Cam, Fullsac X-Pipe Header, Jackpot Muffs, Fuelmoto A/C, Dynojet P-Vision w Autotune
kiohio is offline
post #2 of 19 (permalink) Old 06-19-2013, 03:35 PM
Might consider the Andrews 48 since your 2 up a great deal.
2010 Vivid Black Road Glide Custom
Mike Jesse is offline
post #3 of 19 (permalink) Old 06-19-2013, 03:41 PM
RoadGlideGary's Avatar
Those selections may give you some "hot start" issues - compression release. I looked at them and went with a milder Andrews. Check there web site for specs.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #4 of 19 (permalink) Old 06-19-2013, 03:45 PM
spokanebagfan's Avatar
2012 has the ACR built in to the heads already. should not be an issue. I wentwith the 57 h recently. Like it alot. The low end is not the great point of this cam, but abive 2600 rpm it pulls real nice. the other 2 i really don't know much about. i am running it with the Dragula, Thndermax and screaming eagle big sucker. i think the stock comression might be a bit low for the 57 and plan to have the heads done as well. Good luck.
spokanebagfan is offline
post #5 of 19 (permalink) Old 06-19-2013, 04:03 PM
rageglide's Avatar
I too am running the 57H and like it quite well. Honestly it feels same or better than stock cam off the line.
I think bumping the compression a bit using an .030" head gasket would yield good results. I didn't change head gasket, a compression check on my motor showed 200/205, that's quite a bit higher than stock, and it shows.
Some people may not like the intake noise the 57H makes but I think the 48 does it too... some say the 54 doesn't, but I think that cam needs more compression to work it's best.
2012 fltrx
rageglide is offline
post #6 of 19 (permalink) Old 06-19-2013, 04:26 PM
My only issue with it is i have a little flat spot at about 2400-2600, i think i need to open up th t-max and look at it. But agrred i do think a .030 hg would make a big difference.
The cam is noisier, but i have the screaming eagle big sucker and i think it contributes to it as well. Everyone says that intake is loud. SO overall i am real pleased when i rip the throttle. Not sure if it is a great 2 up cam though.
post #7 of 19 (permalink) Old 06-19-2013, 05:17 PM
ldireprophil's Avatar
Whatever cam you chose, along with the right exhaust and tune will be a noticeable difference to the good over stock. My .02, whatever you choose get a TTS tune by someone fluent in the program.
ldireprophil is offline
post #8 of 19 (permalink) Old 06-23-2013, 05:44 PM Thread Starter
I've made my decision.
Will post back with results when all buttoned up and dyno'd
Thanks,
KO
kiohio is offline
post #9 of 19 (permalink) Old 06-24-2013, 11:29 PM
Torqueinc
Guest
Posts: n/a
What did you get ?
post #10 of 19 (permalink) Old 07-01-2013, 10:57 AM Thread Starter
Its a secret.......
kiohio is offline
Torq spec on exhaust head pipe bolts Dmize Intake and Exhaust 4 02-24-2013 07:53 PM
Breather assembly torque spec? TheDoctor Troubleshooting for Road Glides 0 08-02-2012 12:10 AM
2008 & Up Drag Spec Seat NiceTightLutz Sold 6 07-05-2012 04:05 PM
Bar spec questions gjpollman Controls & Handlebars 8 12-20-2011 02:36 PM
Vented Lower Fairing: 2010 Spec Front Fairing Braces. CCRydah Aftermarket Accessories 10 07-25-2010 11:27 AM
